Keurig K550 2 0 Brewer Black Logo
R
Rachel Bunnell Posted on Apr 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my Keurig 2.0 not brewing full cups of coffee and unable to dispense only hot water?
It is making a grinding noise when it tries to begin brewing, and only slowly dripping coffee out. The coffee that comes out is less than what was chosen as a brew size and is incredibly stronger than usual. Also, occasionally it indicates that it's preheating for an extended period of time.
Larry
Level 2:
Habit-Forming:
  • Expert 126 Answers
  • Posted on Oct 05, 2016
 Larry
Expert
Level 2:
Habit-Forming:
Answers
126
Questions
0
Helped
63964
Points
344
I answered a previous question but as this has more information let me suggest you descale your system.
you can purchase a kit at Bed, Bath, and Beyond, or go online and learn how.
2 Related Answers
NiftyInsight
NiftyInsight
  • 15 Answers
  • Posted on Feb 21, 2010
SOURCE: unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
Anonymous
  • 43501 Answers
  • Posted on Aug 07, 2011
SOURCE: The last two mornings when attempting to brew a
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
How do I get my keurig off the hot water setting back to brew
try inserting a K cup instead and see if it reads that and automatically returns to brew.
Why are black particles being dispensed into the hot wqter from my Keurig coffee maker? How can this be corrected?
Hello, Irwin -
Those "small gritty black particles" are most likely coffee grounds which are so small they slip into the hot water and eventually the brewed coffee.
The grind size of your coffee may be too fine. Drip coffee method coffee makers, including the Keurig, require medium or medium-fine grind coffee.
Source of information:
Coffee Grind Size: Why It Matters and What You Should be Using, by Taylor Martin, December 22, 2015
CNET Best Products
https://www.cnet.com/how-to/coffee-grind-size-why-it-matters-and-what-you-should-be-using/
You may wish to check your coffee maker to determine if coffee grounds leaked into the space between the k-cup and the k-cup holder:
https://www.youtube.com/watch?v=jZrQhlQpLbs
Best wishes.
2helpful
My keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
