How to replace ignition switch 2002 dyna low rider ?
1. Remove seat.
1WARNING
To avoid accidental start-up of vehicle and possible personal
injury, disconnect the battery cables before proceeding.
Inadequate safety precautions could result in
death or serious injury.
WARNING
Always disconnect the negative cable first. If the positive cable should contact ground with the negative cable installed, the resulting sparks may cause a battery explosion which could result in death or serious injury.
2. Disconnect battery cables, negative cable first.
3. Unscrew ignition/light lock ring. Push switch back through hole.
4. Cut switch wires approximately 3.0 in. (76 mm) from switch body. The new switch must be spliced into existing wiring harness using splice connectors.
5. After splicing new switch into wire harness, place switch into position. The word "TOP" is marked on the top of the switch body to allow for proper positioning of switch.
6. Install lock ring to secure switch in place.
