The file that you have downloaded MIGHT be corrupted. If you try to install the corrupted apps, you will get the parse error "There was a problem parsing the package". So, try again downloading the app completely and install it.
1st see if you can clear/remove/delete the corrupted netflix app file from wherever it saves it, temp, cache etc
If to complicated i suspect a factory reset OR just settings should clear it though it means setup time needed.
The app file .apk, that you have downloaded might be corrupted. If you try to install the corrupted apps, you will get the parse error "There was a problem parsing the package". So, try again downloading the app completely and install it. https://www.youtube.com/watch?v=RsSrxVoscKo
I would recommend restarting your tablet and trying to redownload the app. Usually a a parse error occurs when there is compiling error with the package (app's data).
Essentially it might not have downloaded correctly so restarting the whole process should skip it right along!
The error "There was a problem parsing the package" is related with
incompatibility of the .apk file.If the .apk file is a backup of
previous version of android then it is not compatible with the current
version of android ICS OS.You can try to install apps from play store
which are compatible with ICS.Also please try to check the following: Go to Settings menu--------------->
Security-------------------------->
Device administration-------------->
Unknown sources----------------->
Check mark Unknown sources
Now try to install the .apk file.Hope it will help
