Picture does not fill the screen. Right side of screen black. What is the fix
SOURCE: VERTICAL LINE ON TH-42PX70B
there is nothing you can do.the display panel is defective and you must replace it
SOURCE: only right side of screen
We are have the same problem, left side has a moving screen, then black bar, then moving screen, then black on the remainder of the right side. This TV has been used very little. Panasonic has a problem and should fix these at no cost.
SOURCE: my tv has no power when turned on th-50px75u
Check the power plug,check the power outlet.Change ur power supply board is dead.
SOURCE: PICTURE FLICKERS ON & OFF & THEN GOES OUT.
If you have a sound and no picture, especially if it flickers then it rules out the main board and CTRL board being bad. You will want to replace the Y-Main board, but when you replace the y-main board you should always replace the upper and lower ybuffer boards because they can short out your new Y-main board.
SOURCE: panasonic p50u20b - picture shrunk into top right hand corner of screen
seems you have found the PiP (Picture in Picture) if you still have the orignal remote press the pip button or the cancel button
