Question about Panasonic Lumix DMC-TZ3 Digital Camera
Screen flickers and pictures have lines across them on my lumix DMC-TZ3
What makes the screen show pink or purple when turned on, the screen flickers and and the pictures have streaks across them
    New Friend:
    Problem Solver:
  • 9 Answers
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
Posted on Apr 12, 2016
Anonymous
SOURCE:
Streaks across the pictures and some flickering on screen
Hi
the LCD screen may be faulty, or the connecting strip loose or corrosion on it, clean, if necessary change.
Apr 08, 2016 | Panasonic Lumix DMC-TZ3 Digital Camera
My LCD goes pink and purple
This usually happens only when the camera is too cold for the CMOS to function properly. Try carrying the camera in an inside pocket until ready to take a photo. This has been my experience. I have no experience with this color change in any other situation.
Oct 08, 2014 | Panasonic Lumix DMC-TZ3 Digital Camera
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
I have had my camera for about 4 years ( I think) It has suddenly gone weird. When I look thru the lens on any setting ,it is pink and purple and the images are disjointed,melting. Very psychedelic. It...
Is the LCD cracked anywhere?. If you send it to Panasonic, they will charge about $200 and not repair it. Instead, they will send you a refurbished replacement which may not be the same model as yours and gave someone else problems (which could still crop up at a later date.)...Your call. If the screen is indeed cracked, you can Google "how to replace the screen on a Lumix DMC-TZ3" and you will find instructions and places you can purchase a new screen for under $50.
Apr 27, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Hi my panasonic DMC-TZ3 screen is very distorted showing a pink and purple colour, it is like this in all modes and the picture is distotred when a shot is taken,
It is ccd imager chip failure problem in DMC-TZ3 and ccd imager chip will be replaced to solve this issue.
CCD Imager chip part number is VEK0L04 and available in PartStore.com for $141
Local camera repair shop will replace it because camera will take apart and expert tech is required to do so.
Thanks.
Feb 27, 2011 | Cameras
Flickering and loss of colour
Problem now solved. I switched the camera on and off a few times and took several test photos. After a few minutes the problem resolved itself. I suspect the cause was condensation, but cannot be sure.
Jan 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Lumix TZ3 zebra stripes in daylight pictures
hello sodaclub, this fault is normally caused from to much light entering through the lens, the shutter is not closing or working at all.
Jun 24, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Video Playback Issue
You need Movie Viewer Software that can Play MOV files. This type of file orginaled with Apple and QuickTime is their free default player. You could google for anothe free one or pay for one that plays .mov files.
Oct 20, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
314 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
