The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Purple streaks, lines and casts across the recorded images are some of the first stages of CCD failure. A blank image will occur when the CCD completely fails. A blank image however is not to be confused with a blank LCD (998bills) where images are recorded OK but nothing is visible on the back, that fault requires the LCD to be replaced by a service centre. As for CCD's, this is a known fault and will most likely be repaired at no charge by Canon if taken directly to them. More detailed information about the CCD problem can be found on the website of your local Canon, as an example, Canon Australia have this page http://www.canon.com.au/support/customer/default.asp?DXI=KnowledgeBase/Customer/KBArticleForm&File=KB01634&productID=powershota80
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
