Control Lock / Child Lock issue. Taking longer to dry is because air flow is compromised. It needs a good clean out, especially at the rear where the pipe and outside vent is.
On this unit, the error code CL9 indicates the child lock feature is activated. Press the temp and and time buttons and hold them for 3 seconds. This should reset the child lock and clear the code.Mar 27, 2019
most dryers are 220. its possible your breaker is half tripped. try cycling the breaker.. you should get 220 across it while its running. (Be careful).
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
# 1 Check to see if your timer is turning as the dryer is running. If not it will need to be replaced.
# 2 You will need to verify that your heating element is coming on when the dryer is running
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
