Philips Phillips SRP1103/27 3-Device Universal Remote Logo
What is code for Vizio TV? - Philips Phillips SRP1103/27 3-Device Universal Remote
Greenbrier International 110064 Universal 6 In 1 Remote code to program a Vizio tv
To program a Vizio TV with the Greenbrier International 110064 Universal 6 In 1 Remote, you can follow these steps:
  1. Turn on your Vizio TV.
  2. Press and hold the "Code" button on the remote until the LED light stays on.
  3. Use the number buttons on the remote to enter the code "11864" for Vizio TVs.
  4. Press the "Power" button on the remote to see if the TV turns off. If it does, press the "Enter" button to save the code. If it doesn't, repeat step 3 with a different code from the list below until you find one that works.
Other possible Vizio TV codes for the Greenbrier International 110064 Universal 6 In 1 Remote include:
  • 11758
  • 11756
  • 11742
  • 11740
  • 11738
  • 11687
  • 11670
  • 11587
  • 11365
  • 11136
Note: If you can't find a code that works for your Vizio TV, you can try the auto-search function on the remote. To do this, follow steps 1 and 2 above, then press the "Power" button repeatedly while pointing the remote at the TV until the TV turns off. Once it does, press the "Enter" button to save the code.
Can I use your remote universal Llz414
Wholesale VIZIO DPS-200PP-190 2950318703 POWER SUPPLY UNIT ,cheap price ,and orginal board ,good quality
https://www.abctay.com/vizio-dps200pp190-2950318703-power-supply-unit-p-1644.html
I have a vizio L13e tv trying to connect to a universal remote need to set ip address please help
I think you may be looking for the remote IR device codes for Vizio TV for your universal remote. I have the following codes listed for Vizio on one of my universal remotes: 1009, 1030, 1346, 1413, 1414, 1415, 1459, or 1461. Set your remote's TV mode to each code to find the one that works on your TV.
4helpful
2answers
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
23helpful
4answers
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
2answers
Code for Vizio tv
It looks like your remote takes a 4 digit code. Try the following codes:
Vizio 0891, 0912,1783
1helpful
2answers
UVERSE REMOTE CAN NOT TURN OFF VIZIO 42' TV
The documentation that came with my U-Verse equipment doesn't list Vizio products, but I have been using 1343 which I saw suggested on another website. AT&T's support site has a new code list (http://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf) showing Vizio under the TV section as 1489 and in the HDTV section as 1429, 1433, or 1439.
None of the codes listed for Vizio work with my Vizio LCD(model VO370M), but the 1343 code I've been using successfully is listed in the new list as an LG HDTV code.
146helpful
13answers
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
57helpful
13answers
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
4answers
Vizio tv
i used the goldstar codes on my vizio tv and it worked
heres a list of codes
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, 172, 196
the code 004 worked on my 32' Vizio HDTV, for the Jumbo Universal Remote
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
