Heat sensor malfunction.
Located near the heater element on the under side will be a thermostat. Its ******* to the tub and its usually at the back. That's the temperature sensor you need to check. If you have a multi meter you can test for continuity through it and if its faulty then it will need to be replaced.
Hello friend, thanks for your post!
I understand that your want to replace the pump inside of your Electrolux dishwasher. From my understanding an "E3" error code is an issue with your wash motor. It could be a problem with the wash motor, wash motor hall sensor, or control panel. In any case these intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
