Samsung Galaxy Avant - No Contract - T-Mobile Logo
T
Tammy Posted on Apr 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I get a HDMI cable for my Samsung Avant? Is this MHL compatible?
HDMI cable for Samsung Avant, where can I purchase a cable?
Ravi
Level 3:
  • Samsung Master 1,682 Answers
  • Posted on Apr 05, 2016
Ravi
Samsung Master
Level 3:
Answers
1682
Questions
Helped
579977
Points
8910
What HDMI cable do you use for a brookstone projector
https://www.projectorcentral.com/Brookstone_hdmi_pico_projector_review.htm
Pocket Projector
Mobile includes an HDMI® compatible cable, MHL cable, 5- to 11-pin adapter and AC adapter. To connect to any device without an HDMI® compatible port, you will need an HDMI® compatible adapter or Apple Digital AV adapter (sold separately). Your device: ... Apple® iPad®, iPhone® and iPod touch® devices.
Brookstone Pocket Projector - Good Dog Digital
Does my metropcs samsung galaxy avant have mhl
Samsung Galaxy Avant: MHL:
Hello. Yes, MHL is available for all Galaxy family devices. You just need to obtain one that is compatible with your phone.
here's the Official one:
MHL 2 0 HDTV Smart Adapter
Note: You will need your charging cable and wall charging adapter. Plug power into the MHL and plug MHL into micro USB port on Galaxy Avant.
This MHL adapter can be used by the listed newer phones directly without a power adapter to show pictures on to your TV screen. It is not recommended to use without plugging in the power cable (that is plugged into the wall charger) if you are going to use the MHL for streaming video or for gaming, because those are power hungry and will deplete your battery within 2 hours or less. Connecting power charges the MHL as well as your device. Make sure your charging cable and wall charger are OEM, else they could just trickle charge your device instead of actually charging it. (some aftermarket chargers are 3V. Samsung's are 5V for the more power hungry Smartphones.)
You may need to turn airplane mode on
on some Galaxy Smartphones it is:
(my Note 4 on Android 5.1.1 is like this)
Settings>Connections>Airplane Mode
On your phone I believe it is:
(depends on the Android firmware version)
Settings>Under section: Wireless & Networks: Select More Settings>then check box for Flight Mode
*** Important ***
if you are trying to connect to the internet to stream to your TV, and Airplane/Flight mode turns off your WiFi, just turn it back on (airplane/flight mode will remain on) ~ some phones do this, some do not, this is carrier specific.. meaning the cellular provider requested the phone to auto do this for some reason
Is LN40C630K1F samsung tv compatible with MHL? If not how do i get my phone mirrored on my TV, is there a way?
The Samsung LN40C630K1F is not MHL compatible. The HDMI port on the TV doesn't understand the signal from the tablet directly. You need an MHL to HDMI adapter: http://www.amazon.com/Cable-Matters%C2%AE-Adapter-integrated-Charging/dp/B00ESM3Q7K/ref=pd_sim_107_2?ie=UTF8&refRID=1A2PE0271GRC99HNF1G9 , instead of an MHL to HDMI cable. Be sure to make sure that the adapter is compatible with your phone. (Not all adapters work with all makes/models.)
I hope this helps.
Are rca tablets compatible with mhl cables
it is possible because RCA is selling mhl cables.
There is nothing definitive but worth a try. Mini HDMI Adapter HDMI Converter Cable
1helpful
2answers
I am trying to connect my Samsung galaxy S4 phone to my Phillips smart TV 55pfl4909 with mhl to HDMI wires, but it's not working. I've watched videos on you tube & its suppose to be simple but mine is not...
The problem with MHL to HDMI is that there are two versions.
a 9 pin and a 11 pin.
Samsung S3 and below use 9 pin and S4/Note3/etc and up use the 11 pin.
Not all samsung use MHL but the S4 does.
Make sure you have the right MHL cable for your device.
I have encountered this problem personally and have bought a universal cable which covers both versions.
My brother has a Sony and also had wrong cable.
Now it works fine with correct cable.
Dec 21, 2014 • Cell Phones
I am trying to connect LG 32LC7D TV to my new Samsung Tab 3 7.0 via HDMI. I bought the MHL adapter and HDMI cable, connected to Samsung Tab charger and connected to TV, but the table and the TV don't...
The Samsung Galaxy Tab 3 7.0 (SM-T21XX) does not support MHL. The Tab 3 8.0 does support MHL.
The manual for the Tab 3 7.0 is available on the product page: https://www.samsung.com/us/support/owners/product/galaxy-tab-3-7-0-wi-fi . The only TV feature listed is using Galaxy Tab 3 7.0 as a remote control for your television. You need to accept the Samsung terms of use to download the manual (expand the section on languages).
I wish that I had better news for you.
Can a XtremeCables micro HDMI cable work on a Galaxy S4 phone?
Not directly. The S4 requires an MHL adapter to provide an HDMI connection externally. The Samsung MHL adapter is the best choice and it offers a full size (not micro) HDMI port.
3helpful
3answers
How can I connect my galaxy s3 cell phone to my tv?
How to connect Samsung Galaxy S3 to TV..
There are 3 ways to do this..
1. You can use a compatible MHL adapter that connects to the micro USB charging port of your phone and then a regular HDMI cable from your TV connects to the MHL adapter that's connected to your phone. You will have to connect the Samsung micro USB charging cable to the MHL adapter in order for this to work.
You will be able to see everything that you do on your device, however you will be limited to how you hold your phone if you are trying to play a game and direct what you see on the screen to the TV.
Note: the MHL adapter may overheat your device if you have it on and working for long periods of time.
Youtube example of MHL to TV:
How to Mirror or connect Samsung Galaxy s3 to TV
2. You can use a remote access app on the phone to view on a PC/TV monitor. Depending on the remote access app, there maybe a lag seeing the image on your screen. Most apps like this are paid apps.
3. The Samsung Galaxy S3 phone has a natively installed software tool on the phone or can be downloaded from the Samsung Galaxy App Store (Available after you set up your Samsung account on your phone) that can link to a compatible DLNA device (most TV's that are 2005 or older). The app is called Samsung AllShare Play, or it may also be called Samsung Link
Youtube video:
How To Use Samsung Link previously AllShare Play
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
