Health & Beauty Logo
Kirk Riley Posted on Apr 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Previous owner had to have speed adjusted all the way down on my pride mobility jazzy 1103 ultra chair. How do i turn the speed back up
wcdoc1953
Level 2:
  • Expert 280 Answers
  • Posted on Apr 04, 2016
wcdoc1953
Expert
Level 2:
Answers
280
Questions
0
Helped
129811
Points
552
You would need a hand held programmer to adjust the controller settings. The least expensive route short of purchasing a programmer is to bring the power chair into a local dealer to get it programmed. Hope this helps.
4 Related Answers
Anonymous
  • 103 Answers
  • Posted on Dec 16, 2009
SOURCE: The battery on the Pride Jazzy 1103 will ot take a
Have the batteries load tested. If they have sat to to long then they will need to be replaced.
Anonymous
  • 232 Answers
  • Posted on Oct 20, 2010
SOURCE: Re: Pride Jazzy 1103 Ultra.
When the power seat lift lowers down, there is usually a bracket that pushes a button under the seat that tells the motor the seat is lowered and the power chair is safe to operate. Sometimes the bracket can get bent and the button does not get pressed when the seat goes down. Check under the seat around the seat post for the button and make sure the bracket is connecting to it. Carefully bend it back into place if it is not hitting the button properly. If the bracket came off, it will need to be replaced.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Mar 29, 2011
SOURCE: pride mobility Jet 3 Ultra
Hi, well as long as it's operating Ok, then we are all good,and perhaps it is something simple, such as there is NO profile, or a Profile hasn't been set, or chosen?
www.pridemobility.com/pdf/...Manuals/US.../US_Jet_3_ultra_om.pdf
above & below, are your manual so you can check settings etc.
www.pridemobility.com/...Manuals/product_owners_manuals.asp
Below is your troubleshooting website How To.
www.pridemobility.com/.../basic_troubleshooting_guides.asp
Dave
  • 27 Answers
  • Posted on Dec 24, 2014
SOURCE: y mom's jazzy 1103 ultra will not operate .
Those blinking battery level LED's are showing a trouble code. Count them ("all of them" is the wrong answer). Then refer to this page:
Pride Mobility Products Corp Basic Troubleshooting Instructions
I know the 1103 isn't on the list, but all the Pride chairs use the same codes. Try the 1107 guide.
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
What are the trouble codes on a jazzy 7 power wheelchair
http://www.manualslib.com/manual/134640/Pride-Mobility-Jazzy-Select-7.html . This is the owner's manual. It describes the trouble codes. You can download it to refer to it again.
How to reset control of quantum power wheelchair
With both the Jazzy and Quantum series of Pride Mobility power chairs, you can adjust or reset programming with a programmer. These are not usually purchased by end-users but your local dealer, vendor, or wheelchair repair center can probably help.
How do you power on the jazzy select chair?
There is a sequence of a button push while moving the joy stick in a certain direction untill it beeps. Check the owners manual for the exact sequence. You can download the manual from Pride's website.
1helpful
My brother who died about 2 years ago left a jazzy 1103 ultra mobility chair. Unfortunatley I cannot work out how to start it. Its all charged but can't find ingnition. Can you help please Anne ...
ana at the top of the joystick is the on/off button just push it and the lights sshould come on the battery level lights should all light up and you can set the speed with the two buttons on each side the left to slow down and the right to speed up. When all the speed lights are lit you are at max speed Hope this helps
2helpful
2answers
Re: Pride Jazzy 1103 Ultra. Chair is acting like the seat is still elevated and the speed is set to slow (with indicator light flashing). Please let me know what should I be checking?
2answers
Y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
1helpful
Replacing battteries in Jazzy 1103 power chair
Here's a quick link to the owners manual for the 1103 that will show you how to replace the batteries on your chair.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_1103_Ultra_om.pdf
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
