Brother HL-2040 Laser Printer Logo
Posted on Apr 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ready light stays on and printer keeps trying to print but there are no documents waiting.
Have turned off and on, with no effect.
Scott Schoemann
Level 2:
Scholar:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 150 Answers
  • Posted on Apr 04, 2016
Scott Schoemann
Expert
Level 2:
Scholar:
Night Owl:
Answers
150
Questions
Helped
47431
Points
344
The printer is trying to initialize. it sounds like the toner cartridge is bad or empty
Testimonial: "Thank you. Nice to know I haven't stuffed it up!"
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
I tried to empty the spool and the job seems to still be stuck...what can I do to cancel the job?
you'll also need to unplug the printer from the power outlet and keep it like that for about 15 minutes. With the spooler empty, this should clear out the memory of the printer and get you back to a fresh start. This happened a lot with HP 1000 lasers, it's the first time I hear another model having the same issue... but the basic problem is the same, the spooler sends a Get Ready command to the printer, then processes the print document and sends it off. If you erase the document before it's sent to print, or the printer doesnt echo with OK to Print, then the spooler sits and waits for the printer to get ready, and the printer for some reason gets stuck with a Get Ready command without responding back. So clearing the spooler and turning off the printer for 15 seconds usually fixes the problem.
If you liked this explanation please vote with a Thumb Up. Thanks.
The printer keeps on initialzing and not printing document
well this can be a memory issue or the motherboard of the printer. Try to do a reset on the printer. Its called NVRAM and will clear the memory completely. Turn the unit off and while off press and hold the green check and the orange cancel. Hold them down as you turn them on and wait until you get permanent storage init. Release the keys and wait until it get to ready (It might ask about language just press the check). Before trying to print again clear the print queue and try something that worked before or a new document (like a new word doc with a few letters)
The power and paper light keeps flashing
This could mean that a 2-sided document was sent to the printer and the printer is waiting for the page(s) to be reinserted to print on side 2. Check your documentation or the HP support page http://h10025.www1.hp.com/ewfrf/wc/product?product=75045&lc=en&cc=us&dlc=en&lang=en&cc=us
for more information.
The power light blinking indicates the printer is preparing to print a document. The resume light indicates 1) needs paper, 2) a paper jam anywhere in the printer, or 3) the ready to print side 2 of the document.
I hope this helps.
Downloaded driver from HP. connected printer via
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready.
Make sure the paper size is correctly defined.
HP LaserJet 1220: all lights are on
Hi
The complete list of the light patterns, causes and what should you do, are there on this link
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=29789&prodTypeId=18972&prodSeriesId=29789&objectID=bpl10633
it looks like this
Type of error Light pattern Recommended action No power - The printer is not connected to a power supply. c00031238.jpg Plug the printer into a power supply.
If the printer lights do not turn on, contact HP. Ready - The printer is ready to print. c00031239.jpg No action is necessary.
To print a configuration/self-test page, press and release the GObutton on the printer control panel. Processing - The printer is receiving or processing data. c00031240.jpg Wait for the job to print.
All lights stay lit when try to print. All the lights along with both ink lights. Have to press the paper feed button, it will shoot out a blank page then print the document. This is becoming very...
hi you can easily solve this problem
the printer lights are blinking it is a catridge problem
please use orginal priter Hp catridge or use any other catridge.
i hope you will solve ur problem
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
3helpful
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
Turn on the printer.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
Green ready light on, but will not print
When you refilled the paper, did you load a different size paper? Try this: on your PC, left click on START, then left click on CONTROL PANEL. Next, left click on PRINTERS. Find your BROTHER on the printers page and view the status box. Does it show READY? Are there any DOCUMENTS pending? Left click (you may have to click twice)on the BROTHER icon. The PRINT QUEUE appear, showing any documents waiting to be printed, and their status. If anything is in the queue, cancel all documents so the queue is clear. Next, RIGHT CLICK on the BROTHER icon . On the drop down menu,left click on PRINTING PREFERENCES. Make sure the settings match the paper you have loaded in your machine. If something is not right (Paper size, orientation,etc) the machine will not print. Carefully check all the settings and correct as necessary. To test, first click OK to exit PRINTING PREFERENCES. On the same menu, left click on PROPERTIES. On the GENERAL tab, left click on TEST PAGE button to generate a test print.
Norman Weimar
Norman Weimar
k24674
