It
means that it is time for the car to receive it's scheduled
maintenance. Different Maintenances - A - B - C - cover different items.
Maintenence is usually alternating, 13k miles, C Maintenance, 26k miles
A maintenace, 39k miles C Maintenace again etc...
The C
Maintence tells you and your service center what services to perform.
Your local Mercedes dealer can tell you what exactly is invlolved in the
C Maintenance for a 2006 E Class.
Bring up the FSS and check what service items are listed for the "C"
service. The "C" only means that approx 3 hrs are required to perform
the service. If the car is still under warranty, I believe the oil
& filter will be free and the rest of the stuff will cost. Here's
some instructions (PDF format).
Hope this helps (remember to rate this answer and leave some testimonial about this free answer).
It is a check engine light.A loose gas cap or oxygen sensor failure are the most common fault.A scanner like the snap on MODIS or equivalent can give the code for the fault.
Control Unit N2/7 (Restraints Systems Control Unit) is defective. Here is where the unit is located; http://ww2.justanswer.com/uploads/eurotec/2009-06-05_014107_Remove_install_airbag_belt_tensioner_control_unit.pdf
