SOURCE: Fisher and paykel vertical freezer N308 model
bec,
Sounds like you are freezing up! The coils are so frost-laden that they will not allow the unit to function. The unit will need a complete defrost. I'm not familiar with the exact layout of this unit but I can tell you that it needs to be shut down, have warm air blown into the fan area and completely freed of ice. If you just leave it open and turned off, this takes about 2 days.
Possible causes: humidity in the air is condensing...very humid area, too much 'window shopping', not closing the door completely, possible damaged door gasket.
Others: (on older units)
Possible defrost timer problem...or low gas. Try the defrost route. We'll go from there.
SOURCE: chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
SOURCE: BLINKING dE(DEFROST) LIGHT ON OUTSIDE DOOR PANEL OF GE TFX27FH.
look for the manual its usually underneath...remove the grille and look inside. sometimes its taped up
i can help you troubleshoot if you find!
SOURCE: Freezer starting to defrost
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Frigidaire has also jumped into
the market with an adaptive defrost board. The fresh food section light switch
and light bulb must work. To initiate a defrost cycle, open the door and push
the light switch in and out 5 times within 6 seconds. The compressor and fans
should shut off and the defrost heater should come on. Open the door and push
the light switch in and out 5 times within 6 seconds to remove the refrigerator
from the defrost mode and back into a cooling mode.
This product comes equipped with an
Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the
Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature
DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature
window and "F" in the refrigerator temperature window will display when the
heater is activated. To deactivate manual defrost, press and hold Freezer
temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN
(COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the
defrost cycle is complete. (approx. 8 minutes)
