Question about Nortel Lands Phones
HOW DO I MAKE MY NORTEL 7310 RING ON MY PHONE
    Top Expert:
  • Nortel Master
  • 29,372 Answers
6ya staff
SOURCE:
Nortel 7310. Mailbox not accepting new Voicemail messages. I do I clear?
You need to delete old messages - the limit is 50. follow the display when using the VoiceMail retrieval method you regularly do.
Jan 11, 2018 | Nortel Lands Phones
Program 7310 nortel phone
Here are the most common programming features:
1. Feature * 0 - Button Inquiry
2. Feature * 1 - External Autodial
3. Feature * 2 - Internal Autodial
4. Feature * 3 - Assign Feature to a Button
Hope this helps!
Aug 04, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I need different ringtones on my Nortel 7310
you should already, intrnal is double ring and external is long single ring. you can set sounds from the softkeys below display.
Nov 12, 2009 | Lands Phones
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
May 18, 2009 | Nortel Business Series Terminal T7208 -...
External Answering Machine Hook up with M7310
Even though the plug that plugs into the wall on an M-7310 looks like the same plug that the answering machine has, it's function is completely different. The information passed on the single pair of wires is enough to make a 24 button 10 button or 8 button system phone work, has no ringing voltage or dial tone for a single line device like your answering machine.
A Nortel system has ports that have that information, but most likely the answering machine was installed BEFORE the phone system lines, which means it only answered the first line.
Try plugging your answering machine into the EXACT location it was before.
Carl
Jan 09, 2009 | NorStar M7310 Corded Phone
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Jan 08, 2009 | NorStar M7310 Corded Phone
My Nortel Meridian M2008 phone will not ring
it may be turned down to low.press the program key and use the scroll bar below the keypad to find your option...hopes this helps
Dec 05, 2008 | Nortel Meridian M26 Corded Phone
Norstar 7310 forwards to Voicemail
Sounds like the phone is set for Call Forward Busy/ No Answer instead of Call Forward No Answer. If you cahnge it call forwarding it should work correctly. ....Mike
Aug 08, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Lands Phones Logo
51 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Sanjaya Sahu
Sanjaya Sahu
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
