Question about American Standard Home
Where can I order jet control knob, as one broke off
Need replacement knob for climate control system. 4 door sedan. ID 1G3NL55M2SM303069
Your best bet would be a salvage yard. Don't think anybody would stock it, maybe in a rack of replacement door handles, knobs, fittings, etc. for Oldsmobiles or GM products. More certain at salvage. Don't waste your time at a GM dealership- they will tell you the Achieva is obsolete and they can't order parts for it in most cases.
Nov 02, 2015 | 1995 Oldsmobile Achieva
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Peavey bandit 112 reverb
It might just be the control knob. My fender's reverb went out and it was just the knob.
Mar 23, 2009 | Audio Players & Recorders
Diverter knob & flap & gasket broke
You will have to pull the top cover off, it fits underneath unto the knob. When you see the bottom, you should be able to tell. The arm of the diverter goes thru the hole and then hooks onto the bottom of the knob.
Jul 21, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Home Logo
246 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
