Here are steps to connect a Samsung soundbar to a Sanyo FVM3982 TV using an optical cable:
Locate the Optical Out port on the back of the Sanyo TV. This port will be labeled "Optical Out" and is usually covered by a small protective cap.
Remove the protective cap from the Optical Out port and plug in one end of the optical cable.
Connect the other end of the optical cable to the Optical In port on the Samsung soundbar. This port may be labeled "Optical In" or "Toslink".
Turn on both the TV and the soundbar.
On the Sanyo TV, use the remote to navigate to the audio settings. Look for an option to set the audio output to "External Speakers", "External Audio", or "Optical Out". Select this option.
Adjust the volume on the Samsung soundbar using its remote control.
Once these steps are completed, the sound from the TV should be played through the Samsung soundbar. If you encounter any issues or don't hear any sound, check to make sure that the soundbar is set to the correct input and that the volume is turned up. Additionally, make sure that both the TV and soundbar are properly connected and powered on.
Some Samsung models can wirelessly connect to each other. You would have to check the manual for your tv and soundbar. Otherwise, the easiest way would be via optical cable.
Please get a optical cable and run it from TV to soundbar for best sound. If you are using aux input on sound bar that will work but it is analog sound. TV needs to have mini audio out or red/white output on it maybe labeled audio out
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
Connect the soundbar either to the TV's optical output. Or use an Optical to stereo phono/RCA converter box and then a pair of stereo phono cables (red & white) to the soundbar.
If it's a very basic soundbar with just a headphone jack input then you can go from the TV's headphone output instead.
As for the Sky box, just leave it connected via either an AV lead or better still a HDMI cable direct to the TV. The TV will send sound out to the soundbar.
