SOURCE: jeep liberty 2008
When you open the hood look on the drivers side of the engine. There will be a pulley(Power Steering Pump) that your belt goes around, right under it on the back side is where your oil filter is located. It hangs down slightly angled towards the front of the vehicle. (This is of course the 3.7 liter V6)
SOURCE: 2008 Jeep Liberty defroster doesn't defrost
IF you have A/C on it.. you might turn it on for a few houres.. it will de-moist the car.. put the blower on the feet and head section ..
SOURCE: I have a 2008 Jeep Liberty sport it has 39600 back-up lights not
If you have tested fuses and bulbs with test light,and they check out,
the next step is to put you jeep in reverse with the key on,and use your test light to probe the wires before they enter the bulb sockets for power,if you have power replace sockets,if not check to make sure wires are still connected to back up light switch on trans,if you find no problem there,replace the switch
Testimonial: "Thank you for the info on my jeep. I brought it to my mechanic and he could not find where the new switch goes.I will bring it to the dealer."
SOURCE: 2008 Jeep Liberty Won't Start and Sentry Key doesn't work.
check battery connections especially the ground
Are you check fuses? and harnesses connections.
