LG WM1814CW Front Load Washer Logo
M
Matt Posted on Mar 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg tromm water solenoid
Water solenoid is leaking cold water
Tedowen
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • LG Expert 536 Answers
  • Posted on Apr 25, 2016
Tedowen
LG Expert
Level 2:
Prodigy:
Answers
536
Questions
0
Helped
264807
Points
943
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 21, 2008
SOURCE: LG Tromm Water filling
water hammer valve at home depot fixes problem for like 20 bucks
Anonymous
  • 1902 Answers
  • Posted on Feb 16, 2009
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Anonymous
  • 3 Answers
  • Posted on Mar 10, 2009
SOURCE: My LG TROMM (WM1812CW) does
This code means that something is blocking either the water drain pipe, pump filter or the pump itself. I had the same problem and removing the filter (as recommended by LG) did not help. It turned out I had a piece of debris stuck in the pump propeller itself and consequently the water would not drain and the wash would not finish, prompting the error. This is what I did to fix the problem.
1. I removed the cover on the left bottom corner and the removed the filter and unhooked the little rubber tube (drain).
2. I removed the pump cover (lower left corner of the washing machine) and unscrewed 3 screws holding the pump from the front.
3. I disconnected the power supply and removed the back panel (attached with 4 screws)
4. Disconnected the two hoses (one black, one gray) from the pump.
5. Disconnected the power supply to the pump (I had to cut a plastic tie holding the connector in place in order to bring the connector closer so I can disconnect it).
6. Removed the pump by pressing a little tab that was holding it from the back.
7. Once I removed the pump from the washing machine, I took three screws out of the pump motor, gaining access to the propeller. This is where I found a little piece of plastic. Apparently propeller couldn't spin because of that obstruction.
8. I put the pump back together and attached the hoses. This is easier to do when you have the pump closer to the back opening of the washing machine.
9. I then connected the pump power supply connector, locked the pump back in its place and replaced the screws.
The total repair took less than 45 minutes. The hardest part was to remove and replace the drain tube springs, because I did not have the right pliers (You need decent size pliers or plenty of strength in your hands to squeeze the metal bands).
The tools you need for this repair are:
a philips and flat screwdrivers, large pliers and a sharp knife (to cut a plastic tie)
Anonymous
  • 187 Answers
  • Posted on May 22, 2009
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Cameron Scott
  • 105 Answers
  • Posted on Aug 02, 2009
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
What does it mean when my lg tromm WM2487HRM front load washer slowly fills the tub with water when the washer is off?
most likely water fill valve is defective and leaking. hot water or cold water? replace which ever is leaking
Why won't it do cold wash?
check replace inlet water solenoid unless you hear it click on when you start the machine , there is no power to it or it is faulty and not operating to open the water valve
1helpful
What can cause a washer to not fill with cold water during the wash cycle?
well it would seem these are the possibilities:
1. cold water not turned on
2. hose kinked
3. inlet valves not working
4. wiring issue
5. control board issue
oh and plugged inlet fill filter
good luck
I have water leaking onto the floor from my LG Tromm washing machine. I tried to check for blockage of the hose but it is still leaking.
Check the connections on the back of the washer for the cold & hot water connections. This just happen to me last week. My husband tighten them and resolved the problem. Good Luck !
Cold water keeps running making door open and flood
check for a sticking/leaking cold water inlet solenoid valve at back of the washer, very easy to replace.
1helpful
2answers
High pitched noise during hot water only
This problem is usually caused by LOW water pressure going in the washer.
1. Remove hot water hose and flush all debree from water line.
2. Change water filters and you'll be good to go.
GOOD LUCK!
1helpful
  • Hi
  • Try these:
1helpful
3answers
No hot water entering
1. Make sure water comes out of the hot water hose into a bucket.
2. Check to make sure the solenoid valve is working. The buzzing is the 60Hz on the coil and can make a lot of noise if valve does not operate properly. Try blowing into the hot water port. If the solenoid is functioning properly air will move freely, if not its stuck.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
