Hotpoint Aquarius WMA42 Front Load Washer Logo
M
Michael Posted on Mar 28, 2016
Replacement of bearings?
One of the suspension springs recently snapped on our machine causing a very violent stoppage of the drum. Replaced spring but now machine runs very noisily suggesting a bearings issue. Can I replace bearings myself?
5 Related Answers
Anonymous
  • 1028 Answers
  • Posted on Sep 27, 2008
SOURCE: Hotpoint bearing replacement
remove rear pulley and pull like crazy ..usually have to change rear shell bearing and seal are pressed in be sure to ck spindle on basket for scoring before reassembly if scored replace basket
Anonymous
  • 135 Answers
  • Posted on Dec 19, 2008
SOURCE: the drum bangs on the spin
Two possibles for this are aloose balance block or cracked drum spider.The front block is most prone to coming loose.
To check spider rotate drum little by little and pull towards you to check for movement.
Post back if further help needed.
Thankyou
Anonymous
  • 2559 Answers
  • Posted on Jan 28, 2009
SOURCE: Bearings Replacement
Bearings can be replaced without replacing the drum.
this is a major job,So,I would not recommend trying this yourself
Please rate this fixya
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on May 27, 2009
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 31, 2010
SOURCE: hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Testimonial: "Thanks for your help. In the end it was the front balance weight that had been gradually coming looser and looser and needed fixing pack into place."
Washer vibrates badly in spin cycle.
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Banging on spin
Check this link :
My LG front loading washing machine shakes violently on the spin cycle.
Check this link :
I have an He3t/110 42922200. The drum hits housing on hi speed with a heavy load. Do I replace the drum suspension springs, the shock absorbers, or both?
Check upper springs first as one snaps on this model next make sure machine is level,if all else fails you could replace suspension legs/ struts....
1helpful
My washer shakes real bad when spinning and makes a rumbling noise
You washer drum is running eccentric and so there is violent action while it is spinning in the cycles of wash and spin.
The fault gets unbalanced when the spinning cycle is ON as the clothes loose the weight of water and needs a stabilizing with a damper/suspension system.
Hence a fault in the suspension of the drum can be the element of fault. You will need to check if there is friction in drive system, check for free movement of the shaft.
Make sure the dampers are not faulty if so replace.
Finally check if the spring suspensions have gone out of the frame , changed or shifted.If so realign the springs to have the drum in the center.
Front seal not supporting drum, drum flops violently, doesn,t leak. seal wont stay on drum.
it sounds like you may have tub bearing issues or your suspension springs or shocks may be missing or broken. The front seal is just there for sealing, thats its sole purpose.
Basically there is two parts, the inner stainless steel drum and the outer plastic tub housing. Reach inside and see if you can move the inner stainless drum up and down any significant amount? If so the bearings are most likely shot. If its pretty solid but the outer plastic tub moves, its most likely a suspension issue. You can take off the top to get a much better view of the components.
1helpful
2answers
Fast spin vibration
Is the bearing for the inner drum loose or the drum turning with a wobble (empty)? If that checks ok, then possibly one or more of the outer drum dampers is broken, worn out, or out-of-place. Shake the inner drum in various directions--there should be damped motion in any direction.
1helpful
2answers
Shakes violently during spin
make sure your load is medium to large and mutiple pieces. One large bath mat or towel will cause it not to able to balance the load.
Also there is a service bulletin for excess vibration in these machines.
Read it at servicematters.com tech library, service pointers - Whirlpool Duet Sport and maytag machines (Your Kenmore is made by whirlpool and is a Duet Sport)
Suspension pads? where are they do you have a good diagram?
most suspensions on machines use 2 springs on top of the drum and 2 suspension legs on the bottom. ( similar to a car shock absorber) just make sure the bottom concrete counter weight is not loose , this will cause violent a shake
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
