Thank you Noah, I'll check it out and see how I go, appreciate the response.Thank you Noah, I'll check it out and see how I go, appreciate the response.
You can't post conmments that contain an email address.
Thanks Gerard, have checked the drip tray and water tank, any idea how i can get inside the machine to check the internal pipe? Thanks againThanks Gerard, have checked the drip tray and water tank, any idea how i can get inside the machine to check the internal pipe? Thanks again
There could be a blockage in the group head from pressure in the silicone valve.
tools needed: security-screwdriver-bit-set-102
parts: silicone valve head, spring
yes remove the side panels with the security-screwdriver-bit-set-102 and you'll gain access to the inner portion of the machineyes remove the side panels with the security-screwdriver-bit-set-102 and you'll gain access to the inner portion of the machine
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
