Need to replace magnatron.
Hello Richard;
My name is Peter. I am a retired field service technician.
Your microwave is in a separate housing than your oven. You need to remove the border stripping holding the micro wave in the wall, then lift up in the front and pull out.
Go into the following website, put in your model number which is on a label after you open the microwave door.
You did not tell me what the problem is. Please advise so I can help you further.
Testimonial: "I need to replace the turn table motor and the magamtron"
I do not see the website you mentioned?
Hello Richard; This is Peter again. The website is again: "www.Searspartsdirect.com". Also, go into this website for instruction. This is a major repair.https://www.youtube.com/watch?v=eHkA0it4...
Just for clarification, for myself and future readers, this is a built-in wall oven/microwave combo unit. Looking at the unit I cannot see how microwave unit will come out by itself. I found the installation instructions. The manufacturers pictures and instructions clearly show this combo installed as a single unit. I was hoping it was not. I appreciate Peter's expedient response but I think we may have been discussing two different oven/microwave units.
Richard
Hello Richard; Around the microwave there are border retaining strips. Inside one of your cupboards is a plug to disconnect the power to your microwave. Disconnect the power. Then remove the restraining strips. Lift up and pull out. Leave the oven door open. Pull out the top rack to set the microwave on. I hope this helps. The microwave is on a separate rack.
Thanks Peter. I got the parts I ordered yesterday. I do not have a plug, at least not in any adjacent cabinets. According to installation manual there is only one power cord that is required to be hardwired in a box. I do not think there is enough room above to raise as the control panel covers 1/2 of the cabinet board above. The control panel appears to fastened on the back side as there are no visible screws. There is a vent between the control panel and microwave. It appears to hold the two chrome filler strips on each side of microwave. I'm going to start there and see what I got. But I'm thinking I will probably pull the unit out as that is how the manual shows it installed. I'll keep you posted.
Richard
