Question about Vehicle Parts & Accessories
What's the amperage? - Vehicle Parts & Accessories
  • John Nolan Mar 28, 2016
    Hi Jed Sudol, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
I am trying to find out what should the amperage be for each fuse. i have the fuse card, but it does not tell me the amperage.
If you have the questionable or blown fuse you can tell the amperage value by 1) a marking on the fuse and/or 2) the color of the fuse (if new cartridge type). The owners manual should list all the dudes and locations as well as amperage ratings. If you do not have a printed handbook one can be downloaded via the Internet. You can also look at a similar model car. Last resort is to contact a service shop or dealer. Good luck.
Sep 10, 2017 | Cars & Trucks
Will not read ac or dc amperage
Check the internal fuse - usually there for amperage readings.
Sep 15, 2015 | Fluke Networks Fluke i410 Ac/Dc 400 Amp...
Need the amp rating for the 12v power adapter on Boston BA635 speakers/subwoofer
The bigger the better. It will either get hot if it's not powerful enough, or work ok. The amperage isn't important. The voltage and polarity are. Worst case scenario is you will burn out the adapter if amperage is too low.
Feb 02, 2015 | Audio Players & Recorders
I'm hooking up my connex4600 turbo to batteries
The fuse size will protect the wiring depending on its size but the question is what amperage does the system draw/use and therefore what size wire is needed and the fuse will be the size of the system amperage draw and the wire size also determined by the amperage draw because if the amperage draw exceeds the capacity of the wire the wire will melt so the fuse should project the wire by cutting the current flow when it exceeds the wire siaze but the system needs the cureetn flow, amperage it is designed to use.
Sep 08, 2014 | Car Audio & Video
What is the compressor amperage for Frigidaire Refrigerator?
look at data plate on compressor it will have a fla rating & lra rating one is full load amperage one is locked rotor amperage.
Jun 12, 2014 | Goodman Heating & Cooling
1993 ford escot
A relay is used to switch on high amperage with low amperage.
Think of amperage or current, as water, a low running stream and a fast flowing river.
The relay will magnetize a coil and pull down contacts to make a circuit.
http://www.autoshop101.com/forms/hweb2.pdf
Jul 17, 2012 | 1993 Ford Escort 4 Door
Want to know the wattage of my kenmore coldspot model# 106 41512100
To determine the wattage take the voltage and multiply it by the total amperage.
The total amperage is usually listed where the model number is listed.
WATTAGE = VOLTAGE X AMPERAGE
EXAMPLE: 120 VOLTS X 9.5 AMPS = 1140 WATTS
Mar 06, 2011 | Kenmore Refrigerators
My treadmill shuts off after about 8 minutes of use
The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
Aug 03, 2010 | Proform 7.0 Crosstrainer Treadmill
Whenever i try and turn on unit the breaker pops?
You need to check the maximum amperage the A/C units pulls and compar it to the breaker amperage. The breaker amperage needs to be greater than the A/C amperage. Also A/C's draw more than the rating when they first kick on, so a 15 amp A/C should be on a 20 amp breaker and so on.
Jul 12, 2010 | Heating & Cooling
How to connect to test amperage on a digital multimeter
go to www.actron.com click on digital multitester cp7677, scroll to bottom of page and download the user manual pdf file for detail amperage tests. The manual is free.
Jan 05, 2010 | Actron Digital Multimeter Tester
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Vitally Alcher
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
