It doesn't stop the sound. I am guessing it might be a oven, I am not sure. For the oven part, some how it is not working and only broil sign is on. I cannot turn it off.
Good Afternoon Isaac, thank you for your submission!
I see that your Frigidaire stove is not working but the broil light is on. I would suggest disconnecting power from it for at least ten minutes this is how to perform a factory reset. The factory reset may help clear out any miscommunication within the range and allow it to continue to operate properly. If the reset does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis. I hope the information I have provided is helpful to you. -Matt
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
May be if I can reset the oven, it might be fine. Does anyone know how to reset the oven?
