Just buy one Philips Universal Remote control Model number [CL 034]. You can synchronise it with your Symphonic Combo by entering one amoung the following codes. Proceedings are also given. Note: Switch OFF and Switch On your combo, before entering each code.
Three digit codes for Symphonic are:-
033/ 053/ 189
Four digit code for Symphonic TV/VCR combo is:-
0227
Four digit remote codes for Symphonic tv are:-
0053 0189 0227 0456 0024
Four digit codes for Funai are:-
0051 0189 0053 0227 0456 0042
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
You can also check according to the catelogue of that remote control also. The above given numbers are most common for all universal remote controls. OK.
