Ive followed Klipsch's directions on connecting. The results were the sound was cutting in and out. Ive called Klipsch and they've said its a PCM setting involved with the tv. I have searched the tv's settings and have not found anything concerning a PCM setting.
SOURCE: How do I set up
Cliff, it al depends on what kind of DIRECT TV receiver you have, if it has an HDMI port on the back of the receiver then all you have to do is plug it in and change the input on your TV to HDMI
Enjoy thats a great TV
SOURCE: how to connect a panasonic
What is the source? if you are using an HDMI connection from an HD source you should have digital audio. also, if you are connecting digital cable directly to the TV it will send digital audio out as well. check the optical cable at the amp end to see if it is working. it should glow red at the tip if it is.
there are digital input mode settings as well on some receivers. if it is set to DTS it won't work on PCM audio. if it is set to auto Digital it should work on any standard. check the PCM or DTS options in both the TV, and receiver if those settings are there.
