Need help setting up wireless printer
Step by step set up printer with wireless connection
1. Insert CD Driver came with your printer and run the [Setup]
2. Then klik [Next] to perform the image below
3. Select and Click Wireless LAN Connection, Then Click [Next]
4. Select and Click Acces Point Connection, Then Click [Next]
5. Ensure that your printer is turn on, make sure the white power lamp is on and then click [Next]
6. The sofware will now briefly search your network for any printer already connected. If this is first time you are setting up your printer it will not be found. So please ensure that [setting printer could not be found on the list] is selected, then click [Next].
7. The setup Guide installation will now start
8. Click on [Next]
9. Click on [Cableless setup]
10. When the following screen appears, hold down the [Wi-Fi ] button (A) on the printer until the white power lamp flashes 2 times and release after the second flash, then click [Next].
11. Make sure that the blue Wi-fi lamp flashes quickly and the white power lamp is lit, then click [Next]
12. The following message will be displayeset up printer. - 26140740-lz1mtstkrt32ryhtdlqfftyh-4-20.jpg6140740-lz1mtstkrt32ryhtdlqfftyh-4-20.jpg" alt="26140740-lz1mtstkrt32ryhtdlqfftyh-4-20.jpg" class="h_mi" />
13. Once the connection to the acces point is completed set up printer. - 26140740-lz1mtstkrt32ryhtdlqfftyh-4-27.jpg"/uploads/images/26140740-lz1mtstkrt32ryhtdlqfftyh-4-27.jpg" alt="26140740-lz1mtstkrt32ryhtdlqfftyh-4-27.jpg" class="h_mi" />
14. When the following screen appears, selecset up printer. - 26140740-lz1mtstkrt32ryhtdlqfftyh-4-35.jpgbr>
15. When the following screen appset up printer. - 26140740-lz1mtstkrt32ryhtdlqfftyh-4-44.jpg[Next]
16. When the following screen appears, select the software you wish to install, and then click on [Next]. If you're not sure which software you want to install at this stage, dset up printer. - 26140740-lz1mtstkrt32ryhtdlqfftyh-4-54.jpg at a later stage if you wish.
17. When the following screen appears, click on [Yes] to agree to the end user license agreement.
18. When the folset up printer. - 26140740-lz1mtstkrt32ryhtdlqfftyh-4-65.jpgb>].
19. The software will now instal
If the following screen is displayed during the installation, click on [Redetect] to search for your printer again.
Depending on your network configuration, it may take a mset up printer. - 26140740-lz1mtstkrt32ryhtdlqfftyh-4-77.jpg printer. This may involve clicking on redetect a number of times.
20. Once the Cableless setup is complete the following screen will be diset up printer. - 26140740-lz1mtstkrt32ryhtdlqfftyh-4-90.jpgter and the name (or SSID) of your wireless network. Click [Complete].
SOURCE: I need help setting up
Always load the driver first -the printer setup cd before even attaching the printer. After the printer software is installed then connect the printer, Windows will automatically detect it and voila!. If you do not have the software/driver cd you can download it free from Lexmark.com. along with the manual. Steve Medley
SOURCE: I need to set up my canon color imagerunner for wireless access
What model number is it? I don't think it has wireless printing! You'll need a wireless hub.
SOURCE: MFC-7840W Printer: need tp set the wireless setting, lost the instruc...
To setup your Brother MFC-7840W on a wireless network do the following:
Press Menu.
Scroll down to #5 LAN and hit OK
In the LAN submenu, scroll down to 2. WLAN and hit OK.
In the WLAN submenu select 2. Setup Wizard.
(The printer will search for the SSID of your network. If you are presented with multiple networks, select yours and hit OK.)
Depending whether you have setup a network key on your wireless network, you will have to choose the type of connection. Your options will be Open System, Shared key, and WPA/WPA2-PSK.
If you have a Shared Key or WPA/WPA2-PSK network, then you willhave to enter the key to connect. Open Key does not use a key to connect.
So for instance, if you selected WPA2-PSK you will then be asked to enter your passphrase key to connect to your wireless network.
