It may need a new belt, a new power nozzle motor or the whole nozzle housing needs replaced. It also could be the power nozzle is not getting power from the vacuum which could be a short or bad switch. There are many areas that one or more could be causing the problem. First determine if the problem is in the power nozzle itself or the vacuum then eliminate the possible causes one at a time until you determine the cause. It's much more difficult to find the cause if there is more than one issue causing the problem.
SOURCE: roller brush is not turning on a dyson DC14
http://www.dyson.co.uk/support/help.asp?product=DC07-SY&article=527
here's a link that might help
good luck
SOURCE: I have the Dyson Ball DC24. I can't get the roller
Hi its Darran at Dyson.
The brush bar re-set switch would normally resolve this, however as you have tried that, please get in touch with our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US) so that we can help resolve this issue for you.
Kind regards
Darran
Dyson Customer Service
SOURCE: the brush bar wont spin on my dyson dc 25... i
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
SOURCE: Dyson DC 25 Dyson Ball animal. The bottom brush
Two things you can do.
1- Remove the brush as if you were going to change the drive belt for it.
Clean the brush as best you can and spray some WD40 on the hard rubber/plastic
pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space
between the pieces and the brush axle.
2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation.
If you find this solution helpful, I would appreciate a Thumbs Up from you.
Thank you.
Paul
SOURCE: Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
