Card indicates memory error
what can be done to correct this problem and also save
dictation already on there ?
Hi cazpell,
If you're encountering a memory error, it is often caused by the battery pack. Battery packs included with the DS-4000 are rechargeable battery packs. This problem is likely to happen on the DS-4000 when a NEW battery pack is being used. The battery pack out of the box does not hold enough charge to power up the recorder through its initial start-up procedure.
1. Please turn off the recorder.
2. Remove the battery pack and memory card for 20 seconds.
3. Install the memory card in the card slot.
4. Install new AAA batteries before you turn ON the DS-4000.
5. Your battery pack may also not be fully charged. All new battery packs must be fully charged from 2.5 to 3 hours before first time use.
6. For the first week to 10 days of use, it is recommended to recharge the battery pack as often as possible. This will exercise it and improve its charge-hold capacity.
Hope it helps.
Thank you for using FixYa.
