Question about New Home Sewing Machines
I have a 535 New Home vintage sewing machine would I be able to use a double needle. The machine needle threads from the side and not the front.
  • New Home Master
  • 12,731 Answers
Probably "No." One telling feature is that most machines that will use a twin needle have two thread spool pins on the top. The 535 does not.
There is also the logistics. On a sewing machine with a front-threading needle, the twin needles operate side-by-side so the two threads will appear to be mirror stitches of each other. That would not happen with a side-loading needle (because the double needle would be installed facing to the side and the needles would be positioned one needle exactly behind the other). It would cause the rear thread to simply stitch over the top of the front thread, rather than creating a side-by-side affect.
In addition, the needle plate would have to accommodate a double needle (facing the side) in that space. The bobbin mechanism would also have to accommodate two needles--one behind the other. That is most likely a recipe for disaster--or at least, a broken twin needle and/or damage to the bobbin mechanism.
Here's a manual, if you need one:
New Home 535 Manual Instruction
Posted on Mar 24, 2016
Testimonial: "Thank you so much this just the information I needed and is much appreciated."
  • New Home Master
  • 1,860 Answers
6ya staff
SOURCE:
I have a New Home 622 sewing machine. Can I use a double needle in it ? Thanks.
Most machines can use a twin needle as long as the presser foot and needleplate have a wide opening to allow the needle to penetrate without restriction. However, I believe sewing machines whose bobbins load on the side (as opposed to front-loading bobbins) and the needle faces the side of the machine would not be able to accommodate a twin needle. (Am unable to locate a picture or any information regarding your particular model.)
Jan 15, 2017 | New Home Sewing Machines
How to thread the Nelco A2?
To find a user's manual, search the internet for:
Manufacturer + Model + the word "Manual"
Search YouTube videos for threading tutorials:
Nelco Zigzag Sewing Machine Final Test Demonstration Video
VINTAGE ALL METAL NELCO MODEL 400 2 SEWING MACHINE
NIFTYTHRIFTYGIRL Vintage Nelco model 250 sewing machine
With your Nelco, be sure that you install the needle properly. Frequently, Nelco machines take the needle with the flat side facing toward the throat of the machine--not toward the read like most other machines. The upper thread will thread through the needle's eye from the left toward the right. They also are a left needle position machine--meaning, the standard position of the needle when sewing straight stitch is at the left side of the presser foot, not center like most other machines.
Nov 15, 2015 | Sewing Machines
My sewing machine new home model 535 is breaking top threads all the time i have changed my needle but still breaking can you help
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Nov 28, 2012 | Sewing Machines
I am having alot of trouble finding info for my white e-6354this is a vintage machine I realize but I can't get the top thread to pick up the bobbin thread
Rethread your machine, making sure your needle is not bent or dull, and please make sure that your presser foot is not sitting flat against the needle plate. Make sure you thread needle with flat side behind and the more rounded side facing you.
Lift the presser foot so that it will open the tension disks.
I hope this helps.
Jimmy
Apr 01, 2012 | White Sewing Sewing Machines
New home 535 machine. I've checked the threading, removed any lint or fluff, adjusted the tension and changed the needle. It makes holes but not stitches or gets knotted up and unthreads itself.
check to see if the thread has come off the thread take up lever
check in the needle plate to see if the feed dogs are up or down, if they are down then the knob or switch need to be changed to the up position
if the feed dogs are up then it's possible that they need to be checked
because the feed dogs are what moves the fabric against the presser foot as the machine sews
make sure to have 3 to 6 inch thread tail on top thread & bobbin & pull the thread behind the needle before starting to sew that way the needle does not become unthreaded
and make sure the presser foot in the up position when thread
if none of these suggesions help then it's possible that the machine could be out of time & would have to be serviced by a sewing machine repair tech that has the tools to check the machine
Sep 05, 2011 | New Home Sewing Machines
I have a Necchi 535 sewing machine and the thread tangles
if the thread under the fabric is a matted mess
1.the needle thread tension is to loose
2.needle is either to heavy or to fine for the thread
3.check to make sure the thread isn't off the thread take-up lever
Jul 30, 2010 | Necchi Sewing Machines
I just got a Vintage Singer 600E sewing machine and it came with instructions on how to thread it but not how to get started sewing. I don't know how to bring up the thread from the bobbin to start sewing....
Hold onto the needle thread, turn the drive wheel, on the right side of the machine, until the needle goes down & back up. the bobbin thread should be caught in the loop of the needle thread. Pull it all the way out of the bobbin. and you are ready to sew.
Patchaquilly
May 20, 2010 | Singer Sewing Machines
Double needle use on Juki HZL-E80
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
Jun 16, 2009 | Juki HZL-E80 Computerized Sewing Machine
Sewing Machines Logo
173 people viewed this question
Top New Home Sewing Machines Experts
fordexpert
Harjeet Singh
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
