Microwave runs for 59 seconds, then stops, will start again and run for 59 more seconds etc.
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
SOURCE: Sharp R1870
This
is a problem in one of the damper-related components, most likely the
switch, but it may also be the motor or the damper door.
The
damper is a door inside that opens or closes depending on cooking mode.
If the controller senses that the door is not in the right position, it
will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
You will need the free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics.
If you only need a switch, you can order one from us for $5 postpaid.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: have a sharp microwave and
This
The
SOURCE: Sharp R-1870 stops at 59 seconds
Wow. I just read something ridiculous!
Well, never mind that, here's your solution:
This
is a common problem in one of the damper-related components, most likely the
The
59 seconds.
service manuals for these models and have uploaded it to our site here and here to help you. You will
need the free
Adobe Reader
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
We're
SOURCE: My sharp R1870 microwave/convestion oven turns
This
is a problem in one of the damper-related components, either the switch
or motor or the damper door may be binding.
The
59 seconds.
drawing for a typical damper assembly.
order here.
We're
William E. Miller
[email protected]
Testimonial: "Wow, this person knows his stuff! Great advice. Thanks!!"
SOURCE: I Have a sharp microwave
That would be a problem in the damper assembly, either a bad switch or motor, or the damper door is jammed or blocked. Consult the attached diagram for general reference. The damper switch is the same as the primary interlock (door) switch.
Its location varies by model, but you'll have to take the outer cover off to find it.
The best place to order Sharp parts is Tritronics or you can call them toll-free at 866-779-5835.
If you only need a switch, you can order a universal type HERE
Also, I quote other similar solution...
I had the same problem. Turned out to be the micro switch and damper motor. I replaced both myself and fixed the problem for less than $40.00. The best advice I got was replace the switch, reconnect the motor and make sure the motor runs through a damper door cycle. It didn't run, even though it showed continuity and had power, so I replaced the motor which solved the problem. The micro switch which is activated by the cam on the damper motor has to be cycled within one minute, or the unit shuts itself off. The damper motor on my model R-1870 is found in the right rear section of the assembly when facing it. You have to remove the unit, and remove the outer casing to get to it. The damper is a simple sheet metal door, activated by the motor, and the switch mounts at the top of the motor and is activated by the same cam that activates the door.
Good luck.
