Question about Emerson LC320EM9 32 in. LCD HDTV
My emerson lc320em9 tv will no longer pick up any cable channels but hdmi input works
Have replaced the digital board and power supply board ( with used parts from ebay) and problem still exist have another tv and it works on the same cable have not replaced the power inverter board
  • Vaughn Duff
    Vaughn Duff Apr 19, 2016
    replaced the power supply board rather than replacing the tuner its self, and still wont pick up basic cable channels, it will how ever pick up OTA local stations with and outside antenna
    Top Expert:
  • Emerson Master
  • 76,204 Answers
Check and replace its tuner. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Mar 23, 2016
Testimonial: "thanks, that is what I have been looking at, either replacing the tuner (UTUNATSSP006) or another power supply board from another, one from shopjimmy. would be cheaper and easier"
6ya staff
SOURCE:
SAMSUNG PS42AS5 PLASMA TV POWER SUPPLY FAULT 470MFD CAPACITOR BLOWS NEAR POWER SUPPLY
First thing you should do is to invest in a really good surge protector for your TV. Then when you replace the capacitor again use a good capacitor. Cheaper is not always better. Rubycon seems to do the best for me. There may be other suggestions, however I have the best luck with them.
Apr 03, 2013 | Computers & Internet
Power Supply Issue.
Either one will work for you but you should be able to repair your board for much less than that price. The usual problem with TV and monitor power supplies is a failure of the capacitors on the power supply board. Here is a link to an article that shows what capacitors are and how to tell if they have failed - http://www.ccl-la.com/blog/index.php/capacitors/ You can get the replacement caps for that board for $12 and its available here: http://www.ccl-la.com/catalog/product_info.php?cPath=21_77&products_id=199
Apr 25, 2012 | Philips 26MF605W/17 Television
My Samsung HDTV takes almost a half hour to turn on. I push the on/off button and nothing seems to happen. I do have the TV connected to cable but even when I use the Samsung remote or the button on the...
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and leaking components parts that are calling capacitors parts these capacitors parts are most likely bugles ups or puffing up onto it tops and leaking.These capacitors parts are dying and leaking that why it give the tv power supply board low power and long time to power up the tv.Have all the tools and know basic electronic also can do basic soldering work?Yes,than changes all these dying and leakages bulges ups capacitors components parts with the same Miro Fared and thoes voltages on the capaictors parts like 5 or 10 volts higher than those capacitors parts was in the power supply board u are replacing,these 5 or 10 volts higher rating will help these newly replace capacitors parts withstand heat better and last longer and the operation on the tv power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power suply board for the replacement.
Aug 19, 2011 | Samsung LN-S4041D 40 in. LCD HDTV
After about 3 seconds of powering the tv on, it starts to constantly blink. What could the problem be?
U have all the tools and know basic electronic also can do basic soldering work?Yes.Tv have power supply board problems,that the board where the power a/c cord plug into it.Take the tv aparts,check the tv power supply board carefully and replaced all those components capacitors parts that bulges up or puff up onto it tops.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.Tv will work again,after power supply board is fixed or replacememt.
Jun 09, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
When you plug in the tv it makes a continuous clicking noise and will not turn on.
Tv have a power supply board issues,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or u have all the tools also can do basic soldering work and understanding basic electronic too?Check the tv power supply board carefully for dying capacitors components parts,it is alway bulges up or puffing up onto it tops.Replaces all these dying capacitors parts,will solved this clicking problems.Tv will have stable power again and tv will work.
May 24, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
My samsung ln52a650 blew a fuse during normal operation. one second it worked the next... nothing. popped her open and couldn't find any damage/arc/flash.... exploded parts. i hear this is a common...
U have all the tools and understanding basic electronic and also can do basic soldering?Yes.The tv power supply board,that the board,where the power a/c cord plug into it.Check the whole tv power supply board carefully for dying capacitors components parts.It is usally have bulges or puffing up capacitors parts indication of components capacitors parts are dying and needed replacement.Replacement for those new capacitors component parts with the same Micro ferit and the voltages of those new components capacitors parts in a higher voltages like 5 or 10 voltages higher than the old components capacitors parts u are replacing for a better heat resistance for the tv operation of the tv power supply board for later on tv use.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 08, 2011 | Samsung LN52A650A LCD TV
My Samsung SP-R4232 has some type of power supply issue. I called a tech who came out and verified it. He thought it was the main power board, but wanted $400 to fix it when I found the part online for...
U replaced the tv power supply board,the board u replaced,that is the board where the power a/c cord plug into it?Check ur old power supply board,examines all parts,see if u have any capactors parts are bulging or puffing up on it tops.Yes,than it is power supply board issue.But by replacing the power supply board only get 50/50 chances for the tv to work.Might be the problems,might not be the power supply board issue alone some times.The chances are tv Tuner signal board is dead also.That the board,where the tv incomming broadcasting signal cable plug into it.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 04, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
Panasonic plasma TV will not turn on. Power LED at bottom of TV flashes 10 times periodically. TV rebooted, problem still exists.
U have tools like soldering iron,desoldering pump or desoldering braids,solders?Can u do basic soldering and understand basic electronic?The power supply board,the cause of this problems.The tv power supply board,that the board,where the power a/c cord plug into it.Have dying and leaking gases parts call capacitors.These capacitors are alway bulges up on it tops or puffing up on it tops.These capacitors are dying leaking and not functions correctly anymore.These capacitors,must be replaced.The tv power LED,will stop flashing and have stable power and the tv will work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 24, 2010 | Panasonic Televison & Video
My lg tv is flashing at the bottom and will not turn on
Unplug,replug the tv to reset it self?Not.Take the tv aparts.Power supply board have dead parts,call capacitors,check power supply board,that the board have a a/c power cord plug into it.That the power supply board.Know basic electronic's?Know how to do soldering,have tools like soldering iron and solders?Check power supply board for those dying capacitors parts,alway bulges up on it tops or puff up on it tops.These capacitors must be replaced in the power supply board.Now the tv shuold have stable ur power light and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 04, 2010 | LG RU-52SZ61D 52" TV
Emerson LC320EM9 32 in. LCD HDTV Logo
96 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
