Compressor runs without building much pressure seems to leak from breather hole
I have read both your questions and after taking both into consideration it sounds like it needs new piston rings. On a gas engine it is called blow by but both have a piston with rings on them, as they wear the end gap gets bigger and bigger allowing compressed air to bypass the rings into the crankcase where the oil is, the breather is there to allow air from the room to enter and exit as the piston goes up and down to avoid pressure or vacuum in the crankcase, the air on the top side of the piston is supposed to go into the tank but in your case some of it is going around the piston rings and into the crankcase building pressure and blowing oil out. There is not much inside a compressor like a gas engine, taking the head off and the oil pan should let you take off the connecting rod bolts and push the pistons out the top. This answer is based on the two comments of cant build all the air pressor and it is blowing oil out the crankcase breather. If you hit the 80 psi and unplug the compressor can you hear air coming from the limit switch box that the power cord goes into ? I will wait for your answer to continue.
