Question about JVC GZ Video Cameras
Power not on or USB device not compatible - GZ JVC Video Cameras
    Dedicated:
    Visited the website for 20 consecutive days.
  • JVC Expert
  • 460 Answers
I think your battery is 100% OK, if the power supply is perfect there may be problem with the switch, clean it with contact cleaner spray often press the switch several times.
if the switch contacts are not connecting, this will help it to clear it.
open the cam, check the power supply on the main board, there is a
small fuse on the circuit board test it with. eventually we have to suspect the mother board. if so should change it.
Posted on Mar 24, 2016
6ya staff
SOURCE:
How do I get the usb play on my technical pro rx55uribt
Plug the usb device into the player and power-down - unplug it.
Replug it with the device plugged in and see if there's a change....
Jul 02, 2016 | Technical Pro RX55URIBT Professional...
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
Compatible charging cables for phillips go gear hdd1630/17
Apr 10, 2013 | Philips HDD1630 MP3 Player
Computer doesn't recognize
1. The front USB connected wrong. When the USB line on the main board of the front on the box and USB interface connect the positive and negative corresponding when this will happen at the kind of failure, this also is very dangerous, because at the positive and negative is likely to make USB equipment burn out.
2. USB interface voltage insufficient. When the mobile hard up in front USB port on a possible system can't identify the device's failure. The reason is mobile hard power is bigger request voltage is relatively strict, lead interface may not provide enough voltage, of course, the inferior power may also caused the problem. The solution is to move hard disk don't connect the lead in the USB interface, replace the power supply or inferior low power use as far as possible external power supply hard disk box, if possible.
3. The mainboard and compatibility problems. Ha ha this kind of fault in the most famous is the main board and NF2 the compatibility of the USB. If you are in the NF2 on the main board run into this questions, can install the latest nForce2 special USB2.0 drive and patch, the latest motherboard patch and operating system patch, or if not try to break once the mainboard BIOS generally can solve.
4. System or BIOS problem. When you in the BIOS or operating systems banned USB will take place when USB devices in the system can't identify. The solution is to open and USB device related options
Mar 20, 2012 | Garmin GPSMAP 276C GPS Receiver
My Linksys usb network adapter is not working properly. When i plug it into the usb slot, the power light turns green, the link light is dimmed. then after a few seconds the power light turns off. As a...
There are several situations that could be the cause of the problem. I would try to uninstall all software and drivers related to the USB device, reboot your pc and follow the documentation for proper installation of the software, drivers, and device. Many USB devices are not Plug-n-Play, they require the installation of the software and drivers before you plug the device in. If it is not installed correctly it may malfunction. If this does not work you might check compatability with your version of Operating system, PC etc....If compatable then try installing on a different pc to see if the problem persists.
Apr 30, 2011 | Linksys Wireless-G Broadband Router
I have a hp deskjet f4480 printer. please tell me what hp printer hardware is compatible in order to instal my printer
you just need a USB cable and a power cord as hardware device to install it.
printers have a special USB cable
like the one below
images?q=tbn:ipg__h-upa10dm:
below is the image of a power cord.
images?q=tbn:16iysawf-bw4im:
you can download the driver from HP.COM
Dec 31, 2010 | HP DESKJET PRINTER, HP OR COMPATIBLE
Hp deskjet 3650 printer works very slowly with win 7
tion one: Check the power supply Follow these steps to check the power supply to make sure that it is functioning correctly.
  1. Turn the product so that you can access the rear side.
  2. Unplug the power cord from the back of the product. Figure 1: Unplug the power cord from the back of the product
  3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
  4. Plug the power cord directly into a wall outlet.
  5. Print and time a self-test again.
  • If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet.
  • If the test page takes significantly longer than 30 seconds to print, continue to the next solution in this document.
Solution two: Check the USB connection
  1. Disconnect the USB cable from the back of the HP product. Figure 2: Disconnect the USB cable from the back of the HP product
  2. Disconnect the USB cable from the back of the computer.
  3. Wait five seconds.
  4. Reconnect the USB cable to the back of the product and the computer, according to the following guidelines: The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Connect the small end of the USB cable to the back of the product Connect the other end of the USB cable to the computer
  5. After you make sure that the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
    • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
    • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high-quality. Otherwise, HP recommends using a USB cable that is less than 2 m (6 feet, 6 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
    • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the problem.
    • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
    • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
  6. After checking the USB connection, print and time a self-test page again.
  • If the test page prints in 30 seconds or less , the problem relates to the USB connection. Replace the USB cable or modify the connection to meet the preceding criteria.
Solution three: Check cartridge compatibility Incompatible cartridges can cause the slow printing problem. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge in a language other than English, click the language link near the globe icon (c01906983.gif ) in the upper right corner of your browser. Examine the cartridges in your HP product, and then follow these steps to check which cartridges are compatible with your product. The number on the cartridge label must match the numbers listed on HP SureSupply.
  • If the cartridges are not compatible with your HP product , replace the cartridges. You can order replacement cartridges directly from HP SureSupply.
  • If the cartridges are compatible with your HP product , continue to the next solution in this document.
Solution four: Perform a reset A reset drains the power from the product and returns it to the same settings after restarting.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product. Figure 3:
  3. Disconnect the data cable (USB or Ethernet, depending on how your product is set up) from the back of the product. USB cable Ethernet cable
  4. Unplug the power cord from the wall outlet. Figure 4: Unplug the power cord from the wall outlet
  5. Wait about 30 seconds.
  6. Reconnect the power cord to the product and wall outlet, and then turn on the product.
  7. Print and time a self-test again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Mar 31, 2010 | HP DeskJet 3650 InkJet Printer
USB Drive
Make sure you are matching the compatibility of USB 1.1 and USB 2.0 between the devices (computer and USB devices).
USB 1.1 device will work in USB 1.1 and USB 2.0, but USB 2.0 devices will not work in USB 1.1 plug in the computer.
How many USB ports do you have in the computer? Which ones have you tried other pen drives in? List the USB ratings for each device and port in the computer to further help.
Have the other USB devices been formatted with other computers? The formatting on other systems might not be compatible.
Nov 21, 2007 | Microsoft Windows Vista Ultimate Edition
Video Cameras Logo
114 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
