Canon Ir 3300 B/w Copier image Runner Series Logo
A
Anonymous Posted on Mar 23, 2016
Paper jam err but paper not found - Canon Ir 3300 B/w Copier image Runner Series
Alzubaidi Firas
Level 2:
Habit-Forming:
New Friend:
  • Expert 64 Answers
  • Posted on Mar 26, 2016
Alzubaidi Firas
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
64
Questions
7
Helped
21179
Points
101
Either sensor needs to be cleaned or small torn of paper has to be somewhere inside.
E000302-0001 err while printing in canon c3320i after that the printing in not working
fuser unit drive or rotation error .
please check lower roller or chane fixing flim
ERR 041
Must have Engine (fatal) and Jam Error logs display on the Control Panel or listed on ..... 041. paper jam. switch off the printer, remove its cartridge, look for paper jam or piece of paper jam in the rollers, clean it, place cartilage properly, switch ON the printer. it will work.
2helpful
I have a paper jam i cannot find on a kyrocea fs-1300d any suggestions how to find and correct this problem?
Hi
1. Paper jammed can be found in the paper tray. Just remove all the paper and inspect paper jammed from the feeder roller.
2. Paper jammed can be found in the toner cartridge compartment. Remove the toner cartridge and inspect for paper jammed.
3. Paper jammed can also be found in the rear door of the printer (back door of the print). Check if there is a back door and inspect for a paper jammed into the roller.
4. Paper jammed can be found in the toner cartridge itself. Check for teared paper inside the toner cartridge.
Please let me know if you need more help
1helpful
LexMark x3430 printer
Here is a guide of all possible paper jam locations on the X340 printer. http://bit.ly/cS4lpm
If still no paper is found on any of those places then the printer has a faulty sensor. Depending on the paper jam numeric error is the sensor that may be failing.
2answers
Erre lights on Lexmark E330 what is second one from bottom?
error light on out of paper also toner light is flashing but its a new toner kit and there is no paper jam
2helpful
Printer wil not print there is a err 6a00
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
          To say in detail ERR 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.The offending item needs to be removed or the purge unit needs replacement.            The purge unit is a plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail. move it back and forth about 5 times, close everything up, and restart. Note the the purge unit is NOT the print head! to be more specific: Take out all the ink cartridge, push the cartridge holder back and forth and clean the inside without taking it apart.
            Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit. here goes, the purge unit.
Plz rate this solution.. thank you..
2answers
Printer will not work because of paper jam eror
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
607
Paper has jammed showing error code 0000064 and inform to restart
canon3000 err code 64 restrt machine 10 to20 copy after code please help me
old marine
old marine
ZJ Limited
ZJ Limited
