Microwave Ovens Logo
c
chemic Posted on Mar 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
H 5040 BM has sparking/flashing coming from grill connection inside top of oven whilst microwave is in use causing this connector to glow red
Michael Kierzkowski
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 08, 2021
Michael Kierzkowski
Contributor
Level 1:
Answers
Questions
0
Helped
1698
Points
Wxl7294 is 100% on the money. Had exact same issue. Undid the nut holding the heating element, cleaned them up and did it back up again tightly. No more sparking. You can call Miele to do it too, it will just cost you $250.
Michael Decker
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 02, 2019
Michael Decker
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
7917
Points
21
Often caused when people lose the correct large hand-nut and fit something that isn't microwave-safe. Not sure if you can buy that nut on its own, best to ask Miele.
wxl7294
Level 1:
  • Contributor 3 Answers
  • Posted on May 25, 2018
wxl7294
Contributor
Level 1:
Answers
Questions
0
Helped
2675
Points
6
The same sparking happened to my Miele H4880BP microwave / conventional oven. The problem was solved by tightening up the two nuts which hold the stud for the heating element at the roof of the oven.
Bill Boyd
Level 3:
Top Expert:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Miele Master 53,816 Answers
  • Posted on Mar 22, 2016
Bill Boyd
Miele Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11929667
Points
172802
Take it in for repair as the connection is shorting out from the micro waves
get a quote as most repairs are more than the replacement cost
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
2helpful
When i use the microwave it makes a very loud coughing and spluttering noise and there is a flashing of lights inside. It also smells of smoke. Any help greatly appreciated. I live Bristol, England if they...
proceed according. God bless youIf you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
1helpful
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
see the guide for test the magenetron and another component.
Sparks when starting then goes to pause mode
see this next steps. God bless you
1helpful
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
My Goldstar MV-1310W microwave has sparks flying from the metal plate that's inside on the top.
Microwave ovens do not work well with exposed metal. IF you place uncoated metal in the oven, sparks will occur.
IF the interior of the oven has the metal exposed, it will cause sparking to occur.
There must be NO exposed metal inside a Microwave oven!
1helpful
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Top Miele Microwave Ovens Experts
vince
john h
k24674
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
