You have a couple of options. That said, measure your current gasket carefully to get a proper match. Seal the door properly or you are wasting your time as the seal keeps the temperature down.
Sears PartsDirect: Sears PartsDirect offers official Sanyo compact refrigerator parts, including door gaskets. You can search for the specific part you need on their website. Remember to check the model compatibility to ensure a proper fit. Official Sanyo compact refrigerator parts ' Sears PartsDirect
Parts Town: Parts Town also provides OEM Sanyo refrigerator parts, including the 8330331651800 REFRIGERATION DOOR GASKET. You can find this replacement part on their website as well Sanyo 8330331651800 REFRIGERATION DOOR GASKET ' Parts Town
While failed defrost controls is more normally the reason for poor refrigerator/freezer performance, we can not forget about the door gaskets as being a possible culprit.
First, visually inspect the gaskets for signs of severe deformation or torn areas which could prevent a good seal. If either is suspect, replace the gasket. Also make certain that magnetic gaskets in fact have the magnets.
Next, grab a dollar bill or sheet of printer paper torn to about the size of a dollar bill. Test the gasket on all doors all the way around by placing the bill or paper onto the frame with the door open. Then, close the door, and gently pull the bill or paper out from the closed door/gasket. You should feel some resistance to the pulling motion. Test all door gaskets, all the way around. Replace any gasket which allow the paper to easily pull out of the closed door, or, figure out if there is something preventing the gasket from sealing properly.
Door seal leakage allow not only warm air migration, but moisture migration into the refrigerator freezer section, putting undo load on the cooling and defrost sections to both cool the air and condense the moisture (which is seen as frost on the cooling coils.), and melt the created ice from the cooling coil..
Repair clinic has booth door gaskets the refrigerator gasket is $91.60 The freezer door gasket is $72.95
If the unit is working good it might be worth it to replace the gaskets if unit is in good shape and you only need one of the 2 gaskets I would replace it. if needs both you need to see what a replacement unit costs and make a decision
. Using a good light , flashlight , etc. check your refrigerator and freezer door seals . This is the gasket that seals the door shut when closed . Look for cracks, tears, and possibly bumps in the gasket material. If you notice any of these , replace the door seal gasket . Furthermore , it is always best to replace both door gaskets at same time .
yes.. costs is about $100.00 for a gasket (bought from an appliance store- add 4-6 hours of frustration trying to get the !@#$%^&* gasket to seat flat against the door frame.. Then call the appliance store.. probably about another 75-100$ to have them do it..
hi
When a refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply. Test the door gasket for leaks by placing a dollar bill between the gasket and the door jamb and closing the door. Pull the bill out. If it offers some resistance, chances are the gasket fits properly. If the bill comes right out, or falls out, the gasket is faulty and should be replaced. Test the gasket at several locations around the door. Before you replace the gasket, check the door hinges for leakage.
