SOURCE: how do you change the
To change the time on a Samsung DCS or the newer OfficeServ you can watch this how to clip below. There are lots more video tips at www.abbeytelecom.com
SOURCE: How diow you change time
Watch this clip for changing the time on Samsung phone systems. More at www.AbbeyTelecom.com
SOURCE: How to set up voicemail on a Samsung KPDCS-12B
If an Engineer has previously set up a Mail Box on your Voice Mail, then you need to assign a VMMSG button to that extension. this will allow access to your Voice Mail. I have posted a Voice Mail training video for you to watch- if you need the key setting up, go to youtube and search 'abbeytel' look for the 'how to program a softkey', I hope this helps, written help is available at
http://www.abbeytelecom.com
SOURCE: Our office has Samsung KPDCS-12B
to program the directory on a 12 button handse; Press the TSFR key Enter 200 Enter code 1234 =/- key to enable Speaker key Your next command will be the MMC required. Enter 706 - Speed Name the 2 MMC
To program the system speed dial directory
Enter 705 - Speed dial 12th Button down to toggle between
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
dial 705
I.e. once in 705
Type in speed number, the cursor will tab over to speed dial slot.
Enter 9 followed by the phone number.
Press 12th button down,
Enter name,
Press 12th button. (You will be back at the speed dial.)
Press tab, then enter the next speed dial slot you wish to program.
NB-
( 705 - Speed dial 12th Button down to toggle between)
( 706 - Speed Name the 2 MMC
