Question about Dyson DC59 Animal Bagless Cordless Stick Vacuum
Why doesn't it work?
When on trigger pulled blue battery indicator shows for a second then a red one appears.no power at all.
    Top Expert:
  • Dyson Master
  • 54,951 Answers
Most likely a battery that can't recharge
Posted on Mar 20, 2016
6ya staff
SOURCE:
I have a new Dyson V8 Absolute When I try to charge it nothing happens. When I pull the trigger I have one flashing blue light. HELP
not trying to be a smart a** but which of the two do you have?
1. A flashing blue light indicates that the battery is running low on charge.
2. A fast flashing blue light indicates no power or a temporary fault (e.g. check filter or for blockages).
FYI....A solid blue light indicates that the battery is charging. No light indicates the battery is fully charged. A solid amber light indicates that the battery is not charging due to a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, call the Dyson Helpline.
Best to you.
Feb 20, 2018 | Dyson Vacuums
My new Dyson Serial Number PM8-US-HHB1494A will not charge.
Suspect a dead battery or a defective charger
Dec 28, 2016 | Dyson Vacuums
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Dyson will not start
If the power cells are operational and it will not start; then either the motor is dysfunctional or something is jammed in the intake module. A conduction test with instrumentation can indicate if the motor is the problem, the power cells are not fully charged, or you have a short circuit. Check Fuses.
Feb 26, 2014 | Dyson DC44 Animal Digital Slim Cordless...
DC44 Animal Cordless Vacuum power cuts on and off while trigger is pulled
This doesn't address the intermittent power cut offs...power cuts off intermittently and you have to keep recycling the power 'trigger' to get it to work...total PIA
Dec 17, 2012 | Dyson DC44 Animal Cordless Vacuum
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
No water or soap coming out
the filter could be block under the flow indicator cap,
but water should still come out of the hose
Nov 07, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Dyson DC59 Animal Bagless Cordless Stick Vacuum Logo
100 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Gerry Harvey
Gerry Harvey
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
