Model number is DXA655MP. It worked fine until one day it stopped accepting and ejecting cd's. At first it just wouldn't eject a disc, now it won't even accept a cd into the slot at all. I've checked to make sure there isn't anything stuck in the cd slot, but I'm not sure what else to try.
SOURCE: CD do not eject
I have the same prob with mine right now and thats why I came here was to find the manual. In the manual it states that that when something like this happens you need to hold two buttons for a few seconds and what it does is it resets the cpu in the deck. I had to do it before and yes I was kind of leary of the solution also but IT WORKED!! Now I'll have to dig before posting this otherwise I didnt just create a common solution I talked about it. Ok while holding power/ATT press eject for more than two seconds, and it says careful not to drop the cd~~~DAAA Or to reset the unit: While holding SEL (select) press power/ATT for more than two seconds and that will reset the unit to factory defaults. And this was actually from my owners manual of which I found...
SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
SOURCE: Cd wont eject.
I was having the same issue with my KD-S5050. I also tried the CD eject lock reset with no results. By using the following steps I was able to reset my CD player and it is working properly again. On page two of the user manual is shows how to do a full reset of the cd receiver. While holding SEL (Select), press ATT (Standby/On Attenuator) for more than 2 seconds. This will reset the built-in microcomputer. http://www.fixya.com/Brands/J/JVC/Manuals/kd_s5050_cd_d2ce2654fa2aab37f3ad2b4ce1e33443/images/KD_S5050_CD_D2CE2654FA2AAB37F3AD2B4CE1E33443_2_p2.jpg NOTES: ? Your preset adjustments ? such as preset channels or sound adjustments ? will also be erased. ? If a CD is in the unit, it will eject when you reset the unit. Be careful not to drop the CD.
SOURCE: cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
SOURCE: CD won't eject....
you need cleaning and maintenance on your radio if you want to eject the disk theres a little tiny button on the face you will need a pin push it in and this should eject your disk
