When a call comes in and they transfer it to my desk, my greeting comes on and then it transfers back to the front desk.
SOURCE: Night Service and Diver All Call to Voice Mail
make sure the call rerouting always is setup and points to the vm huntgroup, then check the call rerouting assignment points the answer point extn number to the relevant always alternative in night1 and night2 mode
ie; always alternative 10 set all to Reroute and supply vm huntgroup number then program call rerouting assignment for extn during night1 and 2 to 10.
let me know if this resolves the issue if not it could be a number of other timer related / vm configuration / call routing problems which might require a more indepth investigation
SOURCE: How to transfer voicemail to another external
This cannot be done. Voice mail messages can be transfered between extensions only.
SOURCE: We have a Mitel 5224 on reception on an i3300
you have to call reroute the phone to voicemail
SOURCE: Won't go to Voicemail
Call needs forwarded to voicemail. On mitel 3300 this is programmed in one in the call handling/ call rerouting for depending on the software version. First alternative should be set for voicemail route. If you have a mitel 200 you can do this through the superkey on the phone. Set no answer and if busy to the voicemail hunt pilot numbet.
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
