This is a process to repair: http://fixitnow.com/wp/2010/09/17/diagnosing-the-mysterious-and-elusive-te-error-code-in-lg-washing-machines/
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
SOURCE: washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: SPIN CYCLE WON"T WORK ON WASHING MACHINE...HELP!
It appears your lid switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Problems
related..
Washing
Machine
Front
Load Washing
heatman101
