The Code H-4 Mean the copier needs to be reset. Also I have added a link to help you troubleshoot the copier.
Thread Toshiba studio 120 with error code H4
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
SOURCE: L1 subcode 00
L1-00 indicates feeding is not completed
within the specified time after starting feeding.
(The scan head locking switch is locked)
The white area and the black marking on the shading plate are used to obtain the difference in the CCD level values for judgment of lock. When the difference in the levels of which and black is small, it is judged that the black mark could not be scanned by lock and the trouble code “L1” is displayed.
SOURCE: Error code H4-00 and machine is "locked-up" in scan mode
go into service mode 05 400 set to "0" switch copier off than on
SOURCE: toshiba e-studio error H-4
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
H4 Heat roller low
temperature detection
SOURCE: H4 CODE IN THOSHIBA
H4 indicates Heat roller low temperature detection. U need to check the themistor, heater lamp, themostat.
SOURCE: What does Olivetti d-copia 120 error message H4 mean?
