Euro-Pro Steam Generator EP8001 Iron Logo
S
Stephen thomas Posted on Mar 17, 2016
Tools for repair needed - Euro-Pro Steam Generator EP8001 Iron
How to get Braun curling iron to heat?
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Aug 21, 2016 • Braun Irons
How do you repair the retractable cord on a 1500w iron
So many people make a copy of that iron maybe a local repair shop for tefal, black n decker, or another can do it. Taking things apart sometimes is not worth the trouble of putting back together. sometimes it requires special tools. call around first before you try it yourself
How do you open the back of an iron
the best way is to use the little screwdriver for to open with the help of some plier. Or use the tools for open the back light in car, is the same type .God bless you
3helpful
2answers
How to repair aan electrical iron
If the iron doesn't heat, make sure power is on to the outlet, check the electrical chord, and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical chord . Also test and, if needed, adjust calibration of the thermostat.
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the sole plate. If the iron stains fabric, clean the sole plate, clean the tank with a commercial cleaner, and use distilled or filtered water.
The tools you will need are
  • Screwdrivers
  • Toothpicks or pipe cleaners
  • Sewing needle
  • Commercial electric iron cleaning solution or vinegar and water
  • Commercial sole plate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
Please rate my solution.
1helpful
3answers
Steam gauge is broken and iron will not produce steam
http://www.fixitclub.com/Parts_Components/Appliance_Controls.shtml click the link  Maintenance and repair tools you'll need to fix an electric iron include these:
  • Screwdrivers
  • Sewing needle
  • Commercial soleplate cleaner or baking soda and water
  • Steel wool
  • Emery cloth
  • Metal cooking pot
you will need a speacial tool screw driver  also called as g5 screw driver to open it.available at local repair store. If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
2answers
Where to take iron to Change the switch
There are several small appliance repair shops listed in the yellow pages. I found numerous listings in Miami.
2helpful
Rowenta dg980
I found out that you do not need to remove the security torx screws (you can get a set from Kragen's Auto Supply or Harbor Freight Tools); don't mean to advertise, but they have decent prices for any "Do It Yourselfer' arsenal." Use a wooden popsicle stick and gently pry the soft rubber cover from the front (on either side) toward the cord end, just enough to access the trigger/control switch assy from the top. Good luck and keep in touch.
Hair Dryer cord has electrical shortage
IF you take off about a inch of wire from the plug and re-wire it [somtimes with new plug also] make sure to remember the fuse and this should do the trick.
Top Euro-Pro Irons Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
