I tried wired and wireless both come up same only wireless code is 014
Roku has no web association. Roku Error Code 009 says your TV is associated with the switch, however doesn't approach the Internet. You may utilize another device, for example, a PC or tablet to test if your association with the Internet is working. On the off chance that no association exists, if you don't mind contact for help to reestablish the web association.
https://www.rokuerrorcode009.com/
Fix Roku Error Code 009
Users facing issues with Roku errors so they may call on Roku customer service number 1-888-587-9269 to get details about how to fix Roku error 009 and experts are there to help you 24*7 anytime. Roku users can make a call on Roku Support Number 1-888-587-9269 anytime and get support to sort any kind of issue related to Roku with the help of technicians. Click here to know more:
https://www.hubcustomersupport.com/blog/how-to-fix-roku-error-code-009
Log onto the Roku website and open a chat window. Ther can fix it.
SOURCE: My Player was connected to my internet provider
You have to go to www.roku.com and sign up for an account. Once you have signed up for an account (yes you have to give them your bank stuff in case you use a pay channel) on your account page there at the bottom right of the page is a link to "Link A Player". This is how you get your code.
SOURCE: Roku Customer Service Call 1-8O5-225-669O We are 24 Hour Available Call for Setup-Install-Fix Error
Have you got past the point where the Roku updates itself? If not, connect the Roku to the router via ethernet to get to that point. Make sure you can watch something on the Roku. Then try connecting wirelessly.
2. If you are still having trouble, connect the Roku directly to the modem. (this is temporary). If you can get the Roku to work, the problem is with your router and not the Roku.
3. Restore all the connections - it would be a good idea to reboot everything: Let the modem come back up, then the router, then the Roku.
4. Check for firmware updates for your router.
5. If you are still having trouble, post the make and model number of your router.
SOURCE: my roku device connect to my wireless network but will not connect to local network
Reset your local network!
Just call Netflix they will hook you up.
SOURCE: Unable to connect to roku please try again later.. is the message on the tv screen
I would disconnect the power going to the Roku Stick, wait at least a minute or so, reconnect the stick to the power supply. If this does not work contract customer support at this link: Contact Support
Are you facing Roku error code 009? Then, this simply means that your Roku cannot connect with the internet connection. So, if you are having Roku Error code 009 then try contacting Roku technicians for troubleshooting and fixing the issue right there.
Go to :
Roku Error Code 009
