Some watches, if they are atomic, will change automatically. If your watch is not atomic, you'll need to change it manually.
Testimonial: "it's a clock...not a watch and it's always adjusted itself in the past"
It is an older clock manufactured and programmed before they changed the time change dates. Leave it alone for another 2 weeks or so and I bet you the time will change. If you change it now then later on it will change and be an hour fast.
Look at your computer time. Bet it has not changed either even though it is programmed to change automatically.
my computer time did adjust itself
the clock did not...as it has in the past.
i reset it manually; will see what happens from here/ so far it is keeping correct time
Some clocks/watches were made before the DST was changed to the middle of March. If it is not atomic, then it changes based on the date. If so, it may not update until April when DST used to take affect.
