I am thinking that you have mistakenly crossed 2 or more wires, hopefully you wrote yourself a wiring diagram or there is one inside the motor cover. I don't know if I can find a wiring schematic for this tool. If you still have the owners manual look in there for initial setup and see if they provided one. If you need more help let me know and I will do what I can.
There will be a tag on the motor that will give the specs. Sometimes they are hard to see from the underside and its not easy to remove the top see them. Try lowering the motor (with blade removed) all the way and use a digital camera to reach up into the cabinet and photoqraph the top of the motor. I had to take several since your shooting blind to get a picture of mine.
On the Powermatic 66's the first two numbers are the year in which it was made, so yours was made in 1997. The second set of two numbers is the model. The last numbers I"m unsure of but its my understanding that they represent the manufactured number, so yours was the 1,400th saw made for that year.
I have seen a "buy it now" on Ebay for such a thing. Someone making a vacuum formed generic cover. Looks like it would work, even if it looks like a bubble-boy-solution. Another solution I have seen is a wooden replica with louvers for ventilation. Sheet metal would be a solution if you have a break and press to properly form, other wise it looks like you banged it our with a hammer and scrap metal. I need the same thing and will probably to the wood with a paint that hides the fact...
You may have lost power on one of the wires to the motor. Check the wiring for breaks, if you have a meter make sure there is power to the 2 110 volt wires.
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Your saw motor is equipped with a two speed internal start switch. Over time saw dust will get into the contacts and cause the points to burn. You can pull the end off of the motor and take some 400 grit sandpaper to the contacts to clean them( there are two sets of contacts one works in the out position the other in the in position) it will be the set in the in position that is the problem. Gentle clean them, reassemble the motor end cap and it will work fine. I have to do this about once a year to my saws. I use my saws about 25 hours a week. I have been doing this to one of my Powermatic saws for 31 yrs. now.
