Question about Samsung Xpress SL-C460FW Laser Multifunction Printer - Color - Plain Paper Print - Desktop Copier/Fax/Printer/Scanner - 19 ppm Mono/4 ppm Color Print - 2400 x 600 dpi Print - 19 cpm Mono/4 cpm Color Copy LCD - 600 dpi Optical Scan - Manual Duplex Print - 150
How can I enter the Tech Mode to reset the counters?
Replaced the transfer belt and need to reset the counters but all the sequences and codes we have come across are not working. We can view what the counts are but we need to reset them.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 132 Answers
Imaging drum reset chip Ebay £15
http://www.ebay.co.uk/sch/i.html?_odkw=Imaging+Drum+reset+chip+for+Samsung+Xpress+SL+C410W+Xpress+SL+C460FW+SL+C460W&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XImaging+Drum+reset+chip+for+Samsung+Xpress.TRS0&_nkw=Imaging+Drum+reset+chip+for+Samsung+Xpress&_sacat=0
Posted on Mar 15, 2016
Anonymous
SOURCE:
How to replace dell 1250c fuser?
To reset the life counter:
  1. Enter the printer's Tech Mode by quickly pressing the sequence of keys Menu > Up Arrow > Left Arrow > Tick > Right Arrow > Cancel > Menu. If Tech Mode doesn't appear, press the key sequence again as quickly as possible. A delay in pressing the keys will stop the menu from opening.
  2. Select Tech Menu > Data Setup > Clear Fuser Count.
  3. Restart the printer.
Read More... Replace the fuser and reset the life counter on Dell 5330dn laser...
And Dell Printer Support
Thanks,
Jul 30, 2014 | Dell Office Equipment & Supplies
BizHub c352. Message reads replace transfer unit. It has only gone thru one cycle and I remember that a tech resest it one time before replacing it with this one. I have read about the pulling the unit...
Yes you can reset the transfer unit counter by replacing a fuse in the transfer unit. You must have the proper fuse. There is no way to reset it using the service mode or key sequence. When the transfer unit is re-installed with a new fuse it resets the counter and then the fuse is blown. Deoending on your location I can maybe offer you a source for the part or we can reset the code for you.
Oct 20, 2011 | Office Equipment & Supplies
I have a Xerox Phaser 6110 laser printer. When I try to print, I get Transfer Belt Error. When I go into the Troubleshooting Guide, it states that I get an Internal System Error. I have already tried to...
The "Transfer Belt" error shows up after the printer has printed 60,000 pages. At which time the belt needs to be replaced.
You can try resetting the count, which may clear the message:
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]2.
If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter6. Enter Password 19347. Arrow to Transfer Belt and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 27, 2011 | Office Equipment & Supplies
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
How to fix transfer belt error in my samsung CLX3160fn
3. Select Tech Menu
4. Select DataSetup
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
How can i order the transfer belt for a samsung clx3160fn
The part number is JC96-03611C. Though it might be difficult to find at a local store, you can find it online. Places like facsimile.com or printerbuddy.com stocks it.
After you remove the old one and replace it with a new one. The replace transfer belt error message will not go away until you clear the transfer belt count on your machine. To do this, you will need to follow the steps below.
3. Select Tech Menu
4. Select DataSetup
Nov 29, 2010 | Samsung CLX 3160fn All-In-One Printer
I need to reset the transfer belt counter Samsung ClX -2160
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Mar 09, 2010 | Samsung CLX2160 Multifunction Color Laser...
My window is showing "replace transfer belt soon" what is that and where is it and where do you find a transfer belt?
When transfer belt count 60.000 image need to reset.
Transfer belt (and other consumables) reset follow this procedure:
1. go in tech mode:
Press consistently menu -> # -> 1934 -> menu
2. in tech mode find ->consumables counter -> transfer belt ->reset
3. after 20 sec. power off and power on
If this not help try this:
1.MENU # 1934 MENU
2.Tech Mode (not User Mode)
3.DataSetup
4.Clear All Memory
Oct 27, 2009 | Samsung CLX 3160fn All-In-One Printer
XEROX PHASER 6110 MFP REPLACE TRANSFER BELT MESSAGE
If you have replaced the Image Transfer Belt, and the printer still does not work, you will need to reset the counter. Xerox would not tell me how to do it, so I did some investigating.
3. Select Tech Menu
4. Select DataSetup
May 18, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Samsung Xpress SL-C460FW Laser Multifunction Printer - Color - Plain Paper Print - Desktop Copier/Fax/Printer/Scanner - 19 ppm Mono/4 ppm Color Print - 2400 x 600 dpi Print - 19 cpm Mono/4 cpm Color Copy LCD - 600 dpi Optical Scan - Manual Duplex Print - 150 Logo
2,047 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
