Call Technican Error C2557
SOURCE: konica minolta is getting error c2557, before this it was saying
c-2557 code has to do with you black toner bottle.
how handy are you?
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
SOURCE: Bizhub 350 error code c2557, how can i fix this?
This code happens if you replace drum without replacing developer. Both must be replaced at same time.
SOURCE: c2557 error message
If is a BW 350 go to service mode ( stop 0 0 stop 01) counter apecial part counter reset drum and dev switc off the very quiqly service mode function run f8. Did you replaced drum and developer?
SOURCE: ERROR MESSAGE C2557 - WHATS
C2557 is the code for ATDC sensor failure. ATDC stands for Automatic Toner Density Control. This code is usually caused by either a sensor failure or more commonly a mismatch in what the machine should have for toner density level and what the sensor is seeing. I have even seen this code pop up if the machne is run low on toner. Bad news is it is going to require service. This may require a drum and developer change to resolve as well. So you will need to call your local service company/guy and get it repaired.
Good Luck and Thank You for using Fixya.
wheatlandservices
Testimonial: "thank you very much. the problem got fixed."
Hi DYJO DAVIS, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? a model number would help
model ###################
depend on the model number
