your not going o see a light use a dollar bill or paper to test close door on paper should be unable to remove the paper go around the door testing --door my be in need of adjustments or hinge worn down
An ice build up around the top of the door aperture isn't unusual due to some cold dense air from inside will spill out when the door is opened to be replaced with humid lighter outside air that will tend to remain at the top for a while.
Being frost free doesn't exclude it from this type of ice build up as only ice formed over the evaporator during a cooling cycle will be melted by the defrost heater.
Persistent localised ice build up could be a sign of failing insulation but this will be marked by a cold spot on the outside of the cabinet.
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around.
A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
check the door beeding which make seal between the body and door.Clean with mild cold water and check it is sealing properly while it is closed.check the compresor ,it should be light warm not hot.
The fridge gets its cold air from the freezer--it could be that there is ice build-up restricting air flow from the freezer. See if you can see any ice there...Is it possible to defrost the whole unit for several hours (even over night)?
This is a problem that the factory has released a bulletin on.They have released new hinges, and insulation for inside the door. So far I've only seen the bulletin for Kenmore upright freezers made by Frigidaire. Since it is a Kenmore the bulletin is a Sears Service Flash but the units are identical. For sears its SF46-517. They may extend the service to Frigidaire units but you'll have to contact Frigidaire about that.
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
